I'm having a problem where some devices are connecting on Client PHY: n 20 MHz and running at very slow speeds. Other devices are connecting upon ac 80MHz and receiving much fast connection speeds. Would this be a laptop problem or controller setup issue? Below is what I receive when running the show AP association client-mac.
PHY Details: HT : High throughput; 20: 20MHz; 40: 40MHz; t: turbo-rates (256-QAM)
VHT : Very High throughput; 80: 80MHz; 160: 160MHz; 80p80: 80MHz + 80MHz
<n>ss: <n> spatial streams
Association Table
Name bssid mac auth assoc aid l-int essid vlan-id tunnel-id phy assoc . time num assoc Flags Band steer moves (T/S) phy_cap
Stats
Parameter Value
Channel 132
Channel Frame Retry Rate(%) 2
Channel Frame Low Speed Rate(%) 0
Channel Frame Non Unicast Rate(%) 42
Channel Frame Fragmentation Rate(%) 0
Channel Frame Error Rate(%) 0
Channel Bandwidth Rate(kbps) 1944
Channel Noise 92
Client Frame Retry Rate(%) 3
Client Frame Low Speed Rate(%) 0
Client Frame Non Unicast Rate(%) 0
Client Frame Fragmentation Rate(%) 0
Client Frame Receive Error Rate(%) 0
Client Bandwidth Rate(kbps) 1298
Client Tx Packets 424139
Client Rx Packets 310499
Client Tx Bytes 45428428
Client Rx Bytes 398323111
Client SNR 53
A2c_SM SeqNum, Old SeqNums 174 0
