Good day. We are experiencing wireless client connectivity issues near the far end of the warehouse and I would appreciate any input that you may offer in regards to possibly receiving a stronger wireless signal. Attached is a diagram that would provide a better view of the wireless AP setup.
Nine directional Aruba 277 AP's, with a 80 degree beamwidth, are installed in a warehouse with a floor space roughly 400 feet by 85 feet. The AP's are mounted approximately 30 feet from the floor. Other than the two rows of concrete beams shown in my diagram, there are three rows of shelving that are approximately 15 feet high that run the full the length of the building. AP's 1-6 labeled in my diagram are mounted on the side walls in a staggard fashion concentrating the RF signal across from each other. AP's 7-9 are focusing the RF signal towards the far end of the warehouse. We already know this is not an ideal installation and the original intent was to install all nine AP's the full length of the warehouse on the side walls, five one one side and four on the other, to provide wireless service. Due to no communications rack with network services either in the middle or far-end of the warehouse, and distance limitations of Category 6 cable, all AP's are physically installed within the first half of the warehouse. A wireless survey and installation plan was completed about two years ago but was not followed due to lack of network services and infrastructure. Wireless connectivity on the first half of the warehouse is excellent, we have an issue on the far end where three AP's are focused to provide service and clients have very low signal (1-2 bars) and SNR values are very low (10-18). It is 110 paces from the far end of the warehouse to AP's 7-9, which is about 275 feet. Maybe 275 feet is just too far?
On the master controller, we've already tried an "AP Specific" configuration for AP's 7-9 where the 2.4 GHz radio transmit power was increased to 15 dB and the 5 GHz radio was increased to 21 dB, but there is not much positive change. Any recommendations that may help with the current situation? My initial thought is to recommend that a new communcations cabinet be installed on the far end of the warehouse and the second half of the building be run from that point, basically mimic how the first half if currently installed. A couple other warehouses in the vicinity have AP's installed the full lentgh of the building (5 AP's on one side and 4 on the other) and have much better wireless coverage. Just wondering if someone here has run into this situation before and can provide some advice. Thanks in advance.....
