Multiple Network SSID with multiple VLAN settings (from network assigned & VC Assigned)
  • 1.  Multiple Network SSID with multiple VLAN settings (from network assigned & VC Assigned)
    Posted May 10, 2019 02:23 AM
    I have Aruba HP 2530-48-PEOP and IAP - 303. I set multiple network SSID. Let 's say SSID 1 and SSID 2.
    My VLAN settings from SSID 1 is from virtual controller assigned ip.
    My VLAN settings from SSID 2 is from network assigned with VLAN 7.
    Let's say the IAP is on my switch on port 20. How can I set the VLAN for SSID 2 ?
    I already port 20 as vlan 7 untagged, but seems won't connect. How can I solve this ? Thanks before.
  • 2.  RE: Multiple Network SSID with multiple VLAN settings (from network assigned & VC Assigned)
    Posted May 10, 2019 02:36 AM
    Management vlan / SSID 1 vlan shout be untagged at port 20. Vlan 7 should be tagged at port 20.
    In the VC you can set the vlan for SSID 2 to 7.
  • 3.  RE: Multiple Network SSID with multiple VLAN settings (from network assigned & VC Assigned)
    Posted May 11, 2019 10:14 PM
    Hi Wills. Sorry for late reply.
    Thanks. It worked. I just need to set from untagged to tagged.
