Not able to see any ssid depending on device used
  • 1.  Not able to see any ssid depending on device used
    Posted Aug 26, 2019 09:18 PM
    We are using iap and we're not able to see ssid depending on device used but in my phone all ssids are visible but from my laptop its not there. both my devices are 5g and 2.4g capable please help
  • 2.  RE: Not able to see any ssid depending on device used
    Posted Aug 26, 2019 09:39 PM
    Which device cannot see any SSID?
  • 3.  RE: Not able to see any ssid depending on device used
    Posted Aug 26, 2019 09:47 PM
    my lenovo thinkpad e480. Device is capable of 2.4 and 5ghz
  • 4.  RE: Not able to see any ssid depending on device used
    Posted Aug 26, 2019 09:51 PM
    My lenovo e480. my iphone is able to see all ssid and my colleague's is able to see all ssid using lenovo e480. My iphone is able to see all ssid. were  using the same model of laptop but he is able to see all ssid. Were using 8.5.0.2 os for iap
  • 5.  RE: Not able to see any ssid depending on device used
    Posted Aug 26, 2019 09:56 PM
    What wireless card does your Lenovo have in it?
  • 6.  RE: Not able to see any ssid depending on device used
    Posted Aug 26, 2019 10:31 PM
    Intel Dual Band Wireless AC 3165 ver 19.51.12.3.
  • 7.  RE: Not able to see any ssid depending on device used
    Posted Aug 26, 2019 11:25 PM
    Have you look at the driver settings? Are both laptops running the same chipset and the same driver?
    Sent from VMWare Boxer.
  • 8.  RE: Not able to see any ssid depending on device used
    Posted Aug 27, 2019 01:19 AM
    Aside from the driver is there any possible configuration adjustment for my laptop to detect the ssid?
  • 9.  RE: Not able to see any ssid depending on device used
    Posted Aug 27, 2019 05:16 AM
    What access point?
    What channel is the access point on?  That card might not be scanning the channels that your access point is on.  https://ark.intel.com/content/www/us/en/ark/products/89450/intel-dual-band-wireless-ac-3165.html
  • 10.  RE: Not able to see any ssid depending on device used
    Posted Aug 27, 2019 05:20 AM
    Aruba access point 535
  • 11.  RE: Not able to see any ssid depending on device used
    Posted Aug 27, 2019 05:25 AM
