I'm running a small network with wired and wireless airplay devices all connected on the same subnet with no VLANS, one Aruba 315-IAP and one Apple Airport Extreme.
IOS devices connect to either access point and always see all airplay devices.
OS X clients, wired and wireless, see some/all of the airplay devices, but over time, 5 minutes to a couple of hours, will only see the wired airplay devices. Bouncing the OS X network connection reestablishes the full list of devices, but they soon disappear.
I'm running IAP 8.3.0.5. I have Bonjour, DLNA, Guest Bonjour Multicast enabled as well as all of the airgroup services. I have no disallowed users or vlans. Two SSID's, I tried every option for Broadcast Filtering on the SSID supporting the wireless Airplay devices.
If I put all the wireless devices on the Airport Extreme everything works all the time from all devices. I was hoping to put the airplay clients on the Aruba AP.
All of the airplay devices are visible from the Airgroup user interface with Airplay as an available service. I can ping all airplay devices at all times.
I've turned IPV6 off on every device on the network. I've tried multiple switches, factory reset the switches. The Airplay devices are a combination of commercial devices and raspberry pi's. Both commercial and the raspberry pi's drop from the OS X list without discrimination
I'm not sure how to debug this to find why the OS X devices are unable to see the airplay devices all the time.
Any help is much appreciated
thanks...
