Highlighted
Re: Per User rate limiting and SSID rate limiting in the same time
You will need user accounting to accomplish this. Aruba ClearPass can help you accomplish this.
JayBee
ACDX | ACCX| CCIE (RnS/SP,DC) | ACCP | ACMP | ACSA | ACMA | CWNA | JNCIS | JNCIA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
Highlighted
Thank you Jay.
And what about using the Captive Portal function, can you set first a survey as a Captive Portal and then be connected to the internet?
Highlighted
Yes you can. Please refer to below post:
http://www.amigopod.com/HOWTO/Survey/
Though that was for amigopod (now merged to ClearPass), stil very relavent to what you are after..
JayBee
Highlighted
Undestood. ClearPass it's needed.
Thank you Jay.
