The Rap is in a "homenetwork" och we have a static NAT to the controller. The communication to the RAP works. We can connect to the switch behind the RAP and the client gets adress in corp network.
Yes i have an error, but that wlan has been deleted
(ESK-RAP-CTRL-01) #show profile-errors
Invalid Profiles
Profile Error
wlan virtual-ap "Guest-RAP" VLAN 999 does not exist
(ESK-RAP-CTRL-01) #
I have attached how our "tree" looks like.
Just so i understand it correct. The Wlans that our Cluster got (created at Eslov-Controllers) they "fall down" in the tree, right?
I might have found the problem In the Group "Rap-Controller) ->Wlans _> General->"The Wlan", it was set to forwarding mode "Bridge".
I changed it to Tunnel and then i can see "somthing" is transmitting.
In the Overview the wlan is "aruba-ap", thats not right? Where did that come from? It shold say Guest in my case.
By the way it´s a RAP-109 im doing this on. Have a 303H that i´m going to setup later.
Thanks for the help.
