Roaming between AP-Groups on the same Controller
  • 1.  Roaming between AP-Groups on the same Controller
    Posted Aug 30, 2019 03:51 AM
    we have an Aruba MobilityMaster 8.4 and 2 7210Controller in a Cluster.
    we congfigured some AP groups on the controller cluster.
    Since we upgraded the enviroment to OS8 we have massiv roaming problems wie apple devices.
    Is there a known issu in OS8 for raoming between ap groups?
    Is there some problem with IOS devices on OS8?
    we have fast roaming enabled at the moment.
  • 2.  RE: Roaming between AP-Groups on the same Controller
    Posted Aug 30, 2019 04:03 AM
    If the virtual APs in the ap-groups have the same vlan, you should ot have a problem.
    Please be specific about your massive roaming issue.
  • 3.  RE: Roaming between AP-Groups on the same Controller
    Posted Aug 30, 2019 04:04 AM
    yes, they are in the same vlan.
    Maybe the is an IOS Problem?
  • 4.  RE: Roaming between AP-Groups on the same Controller
    Posted Aug 30, 2019 09:32 AM
    Please describe your problem in detail...
    EDIT:
    Are you saying that a client cannot reconnect when roaming between ap-groups?
