You typically should limit the number of SSIDs that a radio is advertising to 3 or 4. A radio has to broadcast 10 beacon management frames every second for each SSID that it is advertising. These beacons are transmitted at the lowest data rate. This takes away from time that client devices and APs can use to transmit between each other, and can slow down the performance of a network.
I hope this helps,
