Hi ,We have a problem with Aruba7010 Controller running version 6.5.4.9the SSID is not showing for some samsung phones(3)we have another 20 samsung devices that are perfectly working
Could you please help me with this problem ?Thanks
Please be specific about how your SSID is configured and what model phone it is not showing up for. Are you using channels that and older phone will not scan? What model access point is this?
Are you using encryption on your SSID? What is low assurance?
It is an option in Configure->Certificates , by default aruba blocks non TPM deviceshttps://www.arubanetworks.com/techdocs/Instant_83_WebHelp/Content/Instant_UG/Services/Cluster%20Security.htm#Low
That option is for access point management and only applies to older access points that don't have a TPM chip. It should not affect clients.
