Hello, with AP 303, I want to limit the signal : when the customer pass the door and go out he can't connect because he isn't in the local. Can it be possible and how ?
It is not really possible to do that with such precision. You can lower the transmit power of the access point so that it degrades significantly as the user passes the door, but it is almost impossible to disconnect a user when the user passes the door.
