Frequent Contributor II
Re: Solution needed for Same IAP Setting, but different stores
Ah, the one I checked didn't have multiple VC's in the group. For the client with all the VC's they use templates instead of instant GUI. Suppose that is an option but more difficult. Don't know if there are other options.
When IAPs are in the same group, they are broken out by VC. You can make
override changes to just the VC (store).
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Wait, so you can still make group level changes or not?
Contributor I
Okay, so multiple VC's in one AP Group don't cause any problems?
But to make changes on SSID for the complete group, that is not possible. We need to login via Instant Config Gui per VC (Store) to make changes?
