Hello trying to setup MM redundancy on a vmware station but I'm not getting the vrrp setup , any idea's?
On MM1 (primary)
(ArubaMM-VA_56_9C_3B) [mynode] #show switches
All Switches
IP Address IPv6 Address Name Location Type Model Version Status Configuration State Config Sync Time (sec) Config ID
192.168.1.250 None ArubaMM-VA_56_9C_3B Building1.floor1 master ArubaMM-VA 8.6.0.2_73853 up UPDATE SUCCESSFUL 0 2
Total Switches:1
(ArubaMM-VA_56_9C_3B) [mynode] #ping 192.168.1.251 (this is the MM peer)
Press 'q' to abort.
Sending 5, 92-byte ICMP Echos to 192.168.1.251, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 6.696/9.477/11.036 ms
(ArubaMM-VA_56_9C_3B) [mynode] #show ip interface brief
Interface IP Address / IP Netmask Admin Protocol VRRP-IP
vlan 1 192.168.1.250 / 255.255.255.0 up up 192.168.1.253
loopback unassigned / unassigned up up
mgmt unassigned / unassigned down down
(ArubaMM-VA_56_9C_3B) [mynode] #encrypt disable
(ArubaMM-VA_56_9C_3B) [mynode] #show vrrp
Virtual Router 10:
Description Primary-master
Admin State UP, VR State MASTER
IP Address 192.168.1.253, MAC Address 00:00:5e:00:01:0a, vlan 1
Priority 200, Advertisement 1 sec, Preemption Disable Delay 0
Auth type PASSWORD, Auth data: aruba123
tracking is not enabled
(ArubaMM-VA_56_9C_3B) [mynode] #ping 192.168.1.253 (this is the configured VRRP adress)
Press 'q' to abort.
Sending 5, 92-byte ICMP Echos to 192.168.1.253, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0.066/0.1046/0.169 ms
(ArubaMM-VA_56_9C_3B) [mynode] #show database synchronize
Last L2 synchronization time: Wed Jan 22 14:38:41 2020
Last L3 synchronization time: Secondary not synchronized since last reboot
To Master Switch at 192.168.1.251: *** FAILED ***
WMS Database backup file size: 0 bytes
Upgrademgr Database backup file size: 0 bytes
Cluster upgrademgr Database backup file size: 0 bytes
Local User Database backup file size: 0 bytes
Global AP Database backup file size: 0 bytes
IAP Database backup file size: 0 bytes
Airgroup Database backup file size: 0 bytes
License Database backup file size: 0 bytes
CPSec Database backup file size: 0 bytes
Bocmgr Database backup file size: 0 bytes
L2 Synchronization took less than one second
L3 Synchronization took less than one second
Last failure cause: Standby switch did not respond to the start request or is not ready
10 L2 synchronization attempted
10 L2 synchronization have failed
0 L3 synchronization attempted
0 L3 synchronization have failed
L2 Periodic synchronization is enabled and runs every 20 minutes
L3 Periodic synchronization is disabled
Synchronization doesn't include Captive Portal Custom data
Airmatch database gets synchronized periodically. Last synchronization time : 2020-01-22 14:51:55
On MM2 (standby)
(ArubaMM-VA_B8_94_DF) [mynode] #show switches
All Switches
192.168.1.251 None ArubaMM-VA_B8_94_DF Building1.floor1 master ArubaMM-VA 8.6.0.2_73853 up UPDATE SUCCESSFUL 0 2
Total Switches:1
(ArubaMM-VA_B8_94_DF) [mynode] #ping 192.168.1.250 (this is the MM peer)
Press 'q' to abort.
Sending 5, 92-byte ICMP Echos to 192.168.1.250, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 3.635/14.8994/39.939 ms
(ArubaMM-VA_B8_94_DF) [mynode] #encrypt disable
(ArubaMM-VA_B8_94_DF) [mynode] #show vrrp
Virtual Router 10:
Description Secondary-master
Priority 100, Advertisement 1 sec, Preemption Disable Delay 0
(ArubaMM-VA_B8_94_DF) [mynode] #show ip interface brief
vlan 1 192.168.1.251 / 255.255.255.0 up up 192.168.1.253
(ArubaMM-VA_B8_94_DF) [mynode] #ping 192.168.1.253 (this is the configured VRRP adress)
Press 'q' to abort.
Success rate is 100 percent (5/5), round-trip min/avg/max = 0.054/0.0842/0.158 ms
