For some reason, all your APs ended up on channel 3 on the 2.4GHz, and 52E on the 5GHz with on 2.4 pretty low power (9dBm):
Aruba AP BSS Table
bss ess port ip phy type ch/EIRP/max-EIRP cur-cl ap name in-t(s) tot-t flags
00:4e:35:98:a0:f2 KTI Internet ?/? 10.1.0.40 a-VHT ap 52E/18.0/23.0 1 KTI-AP-4-05 0 2d:22h:45m:33s K
00:4e:35:98:a0:f3 KTI ?/? 10.1.0.40 a-VHT ap 52E/18.0/23.0 1 KTI-AP-4-05 0 3d:0h:33m:19s K
00:4e:35:98:a0:f5 KOKIR ?/? 10.1.0.40 a-VHT ap 52E/18.0/23.0 0 KTI-AP-4-05 0 2d:21h:16m:37s
00:4e:35:98:a0:e2 KTI Internet ?/? 10.1.0.40 g-HT ap 3/9.0/19.5 0 KTI-AP-4-05 0 2d:22h:45m:33s K
00:4e:35:98:a0:e3 KTI ?/? 10.1.0.40 g-HT ap 3/9.0/19.5 0 KTI-AP-4-05 0 3d:0h:33m:19s K
00:4e:35:98:a0:e5 KOKIR ?/? 10.1.0.40 g-HT ap 3/9.0/19.5 0 KTI-AP-4-05 0 2d:21h:16m:36s
Did you configure manual channel/power? Please set both to auto for all APs if the signal strength is an issue.
APs should not take channel 3, so apparently, someone changed the default configuration. ARM is changed to use 2.4 channel 1,2,3,4,6,8,1+,7+; change that back to 1,6,11 (and no wide + channels).
For 5GHz disable 80 MHz channels.
Having seen this, if you are familiar with Aruba Instant, I would reset the configuration and start again from scratch (as I don't know what else has been changed from the default). Otherwise, please work with Aruba TAC to get the configuration analyzed and suggestions for fixes.
