ap 360 mesh link for bridging
  • 1.  ap 360 mesh link for bridging
    Posted Aug 14, 2018 07:11 PM
    Hi all
    I am struggling with a mesh link done with two Aruba outdoor 367.
    We have instant OS 6.5.4.3 version.
    The focus is to connect a main bulding to a remote bulding that does not have wired installed.
    So I have set up a Mesh link between Main building ( mesh portal) and remote bulding ( mesh point).
    I can ping the mesh portal from the mesh point with very good measures.
    Also enabled SSid  for a testing vlan and it works good.
    Next step is to deliver wired to the remote site. I read that I need to enable enet0 bridging on mesh point and also check wired profile settings for put it up.
    Is this what I need to get main office wired network delivered via the mesh link?
    Also, is it possible to enable trunk on the ports f the switch and for wired profile to pass more vlans to remote site?
    regards
  • 2.  RE: ap 360 mesh link for bridging
    Posted Nov 21, 2018 07:56 AM
    Hi
    any help on this??
  • 3.  RE: ap 360 mesh link for bridging
  • 4.  RE: ap 360 mesh link for bridging
    Posted Nov 28, 2018 08:00 AM
    Hi
    going to finish this config tomorrow.
    Already have the link working via wireless. This is a 4,5 km link.
    The next step to connect to lan switching ( trunk with vlans) is to do the config of wired profile on both antenas correct?
    Regards
  • 5.  RE: ap 360 mesh link for bridging
    Posted Nov 29, 2018 10:21 AM
    Hi
    Should Enet0 bridging be enable??
  • 6.  RE: ap 360 mesh link for bridging
    Posted Nov 29, 2018 05:15 PM
    yes
    in your wired ap profile:
    forward mode : bridge
    set switchport mode to trunk  - if you want to pass vlan tags over link
