Occasional Contributor I
Re: help configuring AP 125 for first time
Im eyeing on 2400 controller with OS 5.0. You think that is cool enough? Or get a higher model?
What kind of network are you planning to deploy?  There are newer instant APs that do not require a controller...
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
I have a simple network to build. 10 users. 2 AP-125. One 24 port main switch. I have found on ebay:
  • 3200XM 4 Port
  • 2400 Controller 24 FE Ports 2 GE Ports
Which one do you recommend to go for?
The 2400 has POE to power your AP-125s, so if those were your two choices, I would prefer the 2400.  Again, all of these devices are end of life (especially the 2400), so please do your research !  I am just providing limited advice based on your circumstances.
Thanks a lot cjoseph. I know you are extensing help for me. I really appreciate it. Im kiving you kudos as well for yiur answers. I will check newer versions.
If you only have two access points, I would consider the IAP-305 or the IAP-315.  Both do not require a controller and they are currently supported.
I have already purchased the 2 x AP-125. So I better look for a controller. I think S3500-24P controller is a good option. Right?
S3500 cannot terminate APs.  It is only a switch.  It is also discontinued.
soy nuevo en aruba necesito saber si los controles permiten que en un puerto funcionen varios ap
