Occasional Contributor I
licensing
Controller 7010 v 8.5.0
AP x 5 model 535
APs will not pull license from pool.  Started with temp license, moving to purchased licenses  APs just keep rebooting but never pull license from pool
Aruba
Re: licensing
Is this a standalone deployment or Mobility Master environment?   Is the AP coming up as unlicensed on the controller (L flag) or not coming up at all?
Can you share the following from the 7010/managed device you are expecting the AP to come up on:
  • show log system | include <mac of AP>
  • show ap database
  • show ap license-usage
  • show license client-table
AMFX | ACCX | ACDX | ACMX
Re: licensing
thanks clembo
this is a standalone, but in the GUI there are two tiers of control:  Mobility Controller and Aruba7010_2E_D8_6C  Cannot find documentation why is presented in GUI this way for a standalone setup.
The APs come up with flags 2IL
(1)  (Aruba7010_2E_D8_6C) [mynode] #show log system 004e35c4811e
Error : Expecting integer from 1 to 65535
(2)  AP Database
Name Group AP Type IP Address Status Flags Switch IP Standby IP
Ar-AP01 default 535 172.17.60.31 Up 2m:58s 2IL 172.17.60.8 0.0.0.0
Ar-AP02 default 535 172.17.60.32 Up 2m:59s 2IL 172.17.60.8 0.0.0.0
Ar-AP03 default 535 172.17.60.33 Up 2m:59s 2IL 172.17.60.8 0.0.0.0
(3) #show ap license-usage
AP Licenses
Type Number
AP Licenses 5
RF Protect Licenses 0
PEF Licenses 0
Controller License True
Overall AP License Limit 0
AP Usage
Type Count
Active CAPs 0
Standby CAPs [Counted Against Total] 0
Active RAPs 0
Remote-node APs 0
Active MUX 0
Active PUTN 0
Total APs 0
Remaining AP Capacity
Type Number
CAPs 0
RAPs 0
(Aruba7010_2E_D8_6C) [mynode] #show license client-table
Built-in limit: 0
License Client Table
Service Type System Limit Server Lic. Used Lic. Remaining Lic. FeatureBit
Access Points 32 5 0 5 enabled
Next Generation Policy Enforcement Firewall Module 32 0 0 0 enabled
RF Protect 32 0 0 0 enabled
Advanced Cryptography 2048 0 0 0 disabled
WebCC 32 0 0 0 disabled
MM-VA 33 0 0 0 disabled
MC-VA-RW 32 0 0 0 disabled
MC-VA-EG 32 0 0 0 disabled
MC-VA-IL 32 0 0 0 disabled
MC-VA-JP 32 0 0 0 disabled
MC-VA-US 32 0 0 0 disabled
VIA 2048 0 0 0 enabled
(4) Built-in limit: 0
This little set was up and running last week finally, then the controller moved to new location (same trunking setup).  At the same time, the provisional AP license expired, but the purchased AP license should have replaced that.
Aruba
Re: licensing
For the first output; you left out the "| include statement"
show log system | include 00:4e:35:c4:81:1e
I don't have a standalone in front of me, but try disabling PEF and RFP under licensing.   Licence counts need to match for these features and AP licensing.   See image attached.
Re: licensing
Disabled PEF and RFP, will need to watch for a few minutes while APs cycle again (on their own)
Am not getting anywhere with various iterations of this command.  The carot appears under "include" with this iteration
(Aruba7010_2E_D8_6C) [mynode] #(Aruba7010_2E_D8_6C) [mynode] #show log system | include 00:4e:35:c4:81:1e
Invalid input detected at '^' marker.
Re: licensing
clembo - success.  Disabling PEF and RFP - the provisional licenses were already showing expired - seems to have done the trick.  APs are now fully up and clients are connecting.  Your insight much appreciated
