Wireless Water Cooler
last person joined: one month ago
Hang out and socialize with other community members in this off topic forum. Everything from industry trends to hobbies and interests are welcomed!
802.1X Service Enforcement: Certificate Device Hostname
  • 1.  802.1X Service Enforcement: Certificate Device Hostname
    Posted Oct 31, 2019 01:30 PM
    Hi Airheads,
    As part of my 802.1X service for Windows PC's in Clearpass, I want to have an enforcement condition that allows me to look at the hostname in the device certificate and see if it's a valid hostname in AD.
    Is this possible?
    Any help here would be appreciated.
    Thanks in advance,
    az
  • 2.  RE: 802.1X Service Enforcement: Certificate Device Hostname
    Posted Nov 11, 2019 04:00 AM
    Yes for sure, if you're using computer certificate, the certificate should have the name of the computer.
    Put your active directory as a source of Authentication and then create a role mapping for your service which will query the Active Directory to check multiple thinks like : if the computer is trusted, if the computer is still active, etc.
    Please find an example in the screenshot.
