Wireless Water Cooler
last person joined: 17 days ago
Hang out and socialize with other community members in this off topic forum. Everything from industry trends to hobbies and interests are welcomed!
How disable MAC filtering on WiFi profile - OAW4550 controller
  • 1.  How disable MAC filtering on WiFi profile - OAW4550 controller
    Posted Mar 27, 2019 01:35 PM
    Hello Airheads Community!
    First time in this forum so please bear with me.
    Hoping some of you can share some thoughts on this. I manage an OAW 4550 controller that was configured with MAC address filtering on a WiFi profile. Needless to say, being this a manual process (MAC address requested from user> added to DHCP server filter > key phrase provided > device connects) it is cumbersome, prone to errors, and time-consuming for both users and IT. I'd really like to disable this feature and leave it so only the key phrase is required. Thank you in advance for you input.
  • 2.  RE: How disable MAC filtering on WiFi profile - OAW4550 controller
    Posted Mar 27, 2019 02:23 PM
    Here is how the WLAN is constructed:
    AP-Group
        Virtual AP
              SSID Profile  - How an SSID is broadcast
              AAA Profile   - How authentication occurs on the WLAN.
    The AAA profile has a mac authentication profile.  Set the mac authentication profile to N/A in the AAA profile and it will stop checking mac addresses.
  • 3.  RE: How disable MAC filtering on WiFi profile - OAW4550 controller
    Posted Mar 28, 2019 07:22 AM
    Thank you much for your response! I will try this and post an update. Best
  • 4.  RE: How disable MAC filtering on WiFi profile - OAW4550 controller
    Posted Apr 05, 2019 10:56 AM
    Cjoseph,
    Thank much you again for your time to respond, and apologies for my delayed update. I just had the opportunity to do what you recommended and this worked. Also, I disabled the  "Enabled Allow List" under MAC Filters in the DHCP IPv4 range.
    Thanks again!
  • 5.  RE: How disable MAC filtering on WiFi profile - OAW4550 controller
    Posted Sep 19, 2019 04:43 AM
    Dear admin
    We need your help with a controller 7005 how to configured with MAC address filtering on a WiFi profile.
    FYI,
    We have Huawei controller please find the picture below.
    Thanks & Regards,
    S.A.Quadeer
