Almost All AP's on the Same 5Ghz Channel
  • 1.  Almost All AP's on the Same 5Ghz Channel
    Posted Nov 16, 2015 08:20 AM
    We have 85 Access points in 4 school buildings. 2 Buildings have about 1 AP per classroom/per every other classroom. The other 2 buildings have a few APs spread throughout, so those ones make sense to me.
    Its the 2 buildings that have APs in adjacent rooms that are utilizing the same 5GHz channel. Any idea on where to look. We only have "default" groups at this point setup, so I'm wondering if its time to look into doing some custom AP groups, etc.
  • 2.  RE: Almost All AP's on the Same 5Ghz Channel
    Posted Nov 16, 2015 08:38 AM
    What is your regulatory domain?
    Are you running 20mhz, 40Mhz or 80 MHz wide channels?
    Who installed and configured your system?
  • 3.  RE: Almost All AP's on the Same 5Ghz Channel
    Posted Nov 16, 2015 08:41 AM
    Regulatory Domain profile "default"
    Parameter                         Value
    Country Code                      US
    Valid 802.11g channel             1
    Valid 802.11g channel             6
    Valid 802.11g channel             11
    Valid 802.11a channel             36
    Valid 802.11a channel             40
    Valid 802.11a channel             44
    Valid 802.11a channel             48
    Valid 802.11a channel             149
    Valid 802.11a channel             153
    Valid 802.11a channel             157
    Valid 802.11a channel             161
    Valid 802.11a channel             165
    Valid 802.11g 40MHz channel pair  N/A
    Valid 802.11a 40MHz channel pair  36-40
    Valid 802.11a 40MHz channel pair  44-48
    Valid 802.11a 40MHz channel pair  149-153
    Valid 802.11a 40MHz channel pair  157-161
    40Mhz on the a-band only.
    Local company (MOSS) initially installed and configured it, however we (in-house) have added additional APs throughout the years.
  • 4.  RE: Almost All AP's on the Same 5Ghz Channel
    Posted Nov 16, 2015 08:46 AM
    If you are running 40mhz channels, you only have 4 non-overlapping channels.  If you have access points in every room, each access point can probably see 7 to 8 other access points, which means you will have overlap in every room if you are not using DFS channels.  I would move to 20mhz wide channels so that you do not have adjacent access points on the same channel.  You would do that by going into the ARM profile and change "allowed channels for 40mhz" to "none".  I would also change the arm MAX transmit power in the ARM profile to either 12 or 15 so that fewer access points can see each other.
  • 5.  RE: Almost All AP's on the Same 5Ghz Channel
    Posted Nov 16, 2015 08:52 AM
    My only concern with lowering the TX power would be that in the other buildings where coverage is limited to begin with.
  • 6.  RE: Almost All AP's on the Same 5Ghz Channel
    Posted Nov 16, 2015 08:58 AM
    Do this exercise:
    For an access point in the dense building, type "show ap arm state ap-name <name of some ap>".  Type the same thing for the building that is not dense, to see how many access points each access point can see.  APs with an RSSI of 20 or more are "relevant", meaning, APs can hear them and clients can roam to them.  That will give you an idea of your density.
    You can also have a different ARM profile for the sparse building so you have no problems.
  • 7.  RE: Almost All AP's on the Same 5Ghz Channel
    Posted Nov 16, 2015 09:03 AM
    Thanks for that info. So here is the information without modifying the Max TX at this time:
    High Density Building (1st floor AP tested - 2nd floor APs start with a "2"):
    AP-HHS Rm1110 W23:10.1.9.10:6:15:20.5-Edge:enable : Client Density:75
    Neighbor Data
    Name             IP Address  SNR  Assignment  Neighbor Density
    HHS RmW2117 W19  10.1.9.40   25   6/18        51/64/68/79
    HHS Rm1108 W8    10.1.9.32   12   6/12        46/99/61/46
    HHS Rm2108 W12   10.1.9.38   28   1/12        47/58/62/81
    HHS 1113 W3      10.1.9.20   26   1/18        52/79/69/65
    AP-HHS Rm1110 W23:10.1.9.10:161:18:19-Edge:disable : Client Density:2
    Neighbor Data
    HHS Rm1112      10.1.9.12   13   161/12      2/5/100/40
    HHS 1113 W3     10.1.9.20   8    161/15      1/6/50/16
    HHS 2106 W20    10.1.9.66   8    48/18       0/8/0/0
    HHS Rm2108 W12  10.1.9.38   12   165/18      0/1/0/0
    Low Density building:
    AP-SES Rm6115 W1:10.1.9.80:1:18:20.5-Edge:disable : Client Density:2
    Neighbor Data
    SES South Hall W3          10.1.11.104  17   1/20.5      1/3/50/33
    SES Rm6550 W10             10.1.31.7    13   6/18        0
    SES Rm6113 W2              10.1.11.175  32   11/20.5     1/1/50/100
    SES Hall Outside 6138 W16  10.1.11.53   7    1/20.5      0/3/0/0
    SES West Wing Hall W9      10.1.11.138  6    11/12       0/1/0/0
    AP-SES Rm6115 W1:10.1.9.80:161:18:19-Edge:enable : Client Density:0
    Neighbor Data
    SES Rm6113 W2      10.1.11.175  10   161/19      0
    SES South Hall W3  10.1.11.104  6    161/18      0
  • 8.  RE: Almost All AP's on the Same 5Ghz Channel
    Posted Nov 16, 2015 09:06 AM
  • 9.  RE: Almost All AP's on the Same 5Ghz Channel
    Posted Nov 16, 2015 09:07 AM
    I should also note that all of our APs are AP125's. We currently don't have any AC units.
  • 10.  RE: Almost All AP's on the Same 5Ghz Channel
    Posted Nov 16, 2015 09:12 AM
    The principles are the same.
    To answer your main question, if you are running 40 MHz channels, at that density you do not have enough channels. You should run 20 MHz channels to avoid overlap.
