Aruba Airwave
last person joined: 7 days ago
AMP™ 8.0.9.1 due for update
  • 1.  AMP™ 8.0.9.1 due for update
    Posted Apr 02, 2021 12:39 PM
    I've hererited the management of a Airwave wifi infrastructure.
    I have to update the Airwave server from 8.0.9.1 to 8.2.11.1
    The AP's will also have to be updated from 6.3.1.1 to 6.5.4.19
    Can I update to the current version without breaking anything?
    Can you point me to a good online documentation?
    Many thanx in advance.
    Dany
    Mels Network
  • 2.  RE: AMP™ 8.0.9.1 due for update
    MVP EXPERT
    Posted Apr 02, 2021 04:01 PM
    Hi Mels,
    The latest version recommended is 8.2.12.1 and have some security patches, always check the following website:
    • https://www.arubanetworks.com/support-services/end-of-life/
    • https://www.arubanetworks.com/support-services/security-bulletins/
    You could find the available upgrade path in the release notes.
    Important notice is that 8.2.10.1 introduce CentOS7 (older was CentOS6). When update 8.2.10.1 a re-installation and put back a configuration backup of the same version is the only option to get on CentOS7. Any update after 8.2.10.1 require CentOS 7.
    See also one early post on this topic: https://community.arubanetworks.com/community-home/digestviewer/viewthread?MID=33458
    Hope this helps
    Marcel Koedijk | MVP Guru 2021 | ACMP | ACCP | ACDA | Ekahau ECSE | Not an HPE Employee | Opionions are my own
