Wired Intelligent Edge
AOS-CX IPv6 - SLAAC
This thread has been viewed 24 times
  • 1.  AOS-CX IPv6 - SLAAC
    Posted Jan 10, 2023 06:40 PM
    Edited by DWan Jan 10, 2023 06:47 PM
    The objective of this post is to help understand and discuss AOS-CX IPv6 - Stateless Address Auto-configuration/SLAAC.
    We covered AOS-CX IPv6 - IPv6 address types, Link Local Addresses, solicited-node multicast addresses, duplicate address detection, ICMPv6 Neighbor Solicitation/NS, GUA for BGP peering, GUA for inter subnet connectivity and Unique Local Addresses/ULA previously in
    https://community.arubanetworks.com/discussion/aos-cx-ipv6-link-local-addresses
    https://community.arubanetworks.com/discussion/aos-cx-ipv6-link-local-addresses-part-2
    https://community.arubanetworks.com/discussion/aos-cx-ipv6-global-unicast-addresses
    https://community.arubanetworks.com/discussion/aos-cx-ipv6-unique-local-addresses
    Static GUA IPv6 addresses are typically configured on critical network infrastructure devices such as routers and servers.
    For hosts that do not require static IPv6 addresses, SLAAC or DHCPv6 which depend on ICMPv6 Router Advertisement/RA can be used for dynamic IP assignment.
    SLAAC:
    - Allows GUA IPv6 addresses to be dynamically allocated to hosts without relying on a DHCPv6 server
    - Allows a host to generate its own GUA using the RA sent by the L3 default gateway
    - Default gateway information is sent in the RA and the router link local address is typically used as the default gateway
    The ICMPv6 RA sent by the L3 default gateway will provide default gateway information and guide host behavior with regards to IPv6 address assignment.
    However, final behavior is still dependent on the host OS , e.g. Some hosts might not support DHCPv6, some hosts might use SLAAC if the DHCPv6 server is unreachable.
    Managed address configuration (M), Other Configuration (O) and Autonomous address-configuration (A) flag bit combinations in the RA message will help IPv6 hosts determine if SLAAC or DHCPv6 should be used.
    To indicate SLAAC should be used by hosts, the router should send M/O flags set to 0 and A flag set to 1.
    We will use this topology, an AOS-CX switch, a windows host and a linux host can be seen in our example.
    ULA on Lo0 is used to verify hosts can communicate beyond their local subnet.
    AOS-CX supports sending DNS Search List/DNSSL and Recursive DNS Server/RDNSS information together with SLAAC.
    This will allow IPv6 hosts to derive DNS information while generating it's own GUA.
    This sample config will set the M and O flags to 0/off, while leaving the A flag to 1/on.
    interface vlan2001
     ipv6 address 2001:db8:2001::1/64
     ipv6 address link-local fe80::1/64
     no ipv6 nd suppress-ra dnssl
     no ipv6 nd suppress-ra rdnss
    ! Allow RA with RDNSS/DNSSL info, it is suppressed by default
     ipv6 nd ra dns search-list local.net
     ipv6 nd ra dns server fd25:bccf:1ffa:102::10
    ! Send RDNSS and DNSSL information
    Here is a packet capture of the RA sent to ff02::1 (all hosts).
    Here is a screenshot of a Windows host with SLAAC working as expected.
    You can see it has an IPv6 address ending with :e386 assigned and a temp IPv6 address ending with :e257 assigned.
    It uses link local fe80::1 as default gateway to communicate beyond it's local subnet.
    It has DNS server and DNS search list from RA.
    It can ping to the ULA using it's link local default gateway.
    Here is a screenshot of a Linux host with SLAAC working as expected.
    You can see it has an IPv6 address ending with :7ecf and another IPv6 address ending with :e68c assigned.
    Interestingly, the 2nd IPv6 address is not labeled temp, this is an example of different host behavior, windows vs linux.
    From the switch perspective.
    AOS-CX# sh ipv6 nei
    IPv6 Address                                                            MAC                                Port                 Physical Port       State
    2001:db8:2001:0:24c7:19b4:950d:e257              00:50:56:9e:63:9a         vlan2001         1/1/47                  reachable <- Windows host
    fe80::6101:49e6:c661:e386                                   00:50:56:9e:63:9a         vlan2001         1/1/47                  reachable <- Windows host
    fe80::4852:5683:ed5b:f967                                   00:50:56:9e:dc:27         vlan2002         1/1/31                  reachable
    2001:db8:2001:0:5c81:9d98:16a0:e68c              00:50:56:9e:37:55         vlan2001         1/1/47                  reachable <- Linux host
    fe80::791a:9c93:73de:9949                                  00:50:56:9e:37:55         vlan2001         1/1/47                  reachable <- Linux host
    2001:db8:2001:0:1c38:2f32:d2cf:2014               00:50:56:9e:dc:27          vlan2002         1/1/3                    reachable
    Total Number Of IPv6 Neighbors Entries Listed: 6.
    We can see windows host (MAC ending with 63:9a) has IPv6 neighbor mapping for it's temp GUA IPv6 address (ending with :e257) and link local address.
    This means the temp IPv6 address (ending with :e257) is used to communicate beyond the subnet, the other IPv6 address (ending with :e386) is not used.
    While the linux host (MAC ending with 37:55) has IPv6 neighbor mapping for it's GUA IPv6 address (ending with :e68c) and link local address.
    This means the IPv6 address (ending with :e68c) is used to communicate beyond the subnet, the other IPv6 address (ending with :7ecf) is not used.
    As shown above, you have seen how Windows/Linux hosts and AOS-CX switch interact when SLAAC is used.
    If you have questions, let's discuss!
    DWan
