Starting new topic (original post https://community.arubanetworks.com/t5/Developer-Community/AOS-CX-Ansible-Role-in-Galaxy/td-p/550650)
I am trying to test the Ansible module for CX in my lab with the 10.04 OVA, but I have a hard time to get the basic connection to work.
I first added the role to my existing Linux Mint test host, that gave me error below.
Then I installed a clean, new Ubuntu 18.04LTS host, followed the instructions of the other article (https://community.arubanetworks.com/t5/Developer-Community/How-to-Install-Ansible-and-Aruba-Ansible-Modules-on-Ubuntu-18-04/m-p/555488)
But when I try the basic L3 port or the vlan config example, the play shows an error. When I run it with the verbose option, I get this error output:
An exception occurred during task execution. To see the full traceback, use -vvv. The error was: AttributeError: 'NoneType' object has no attribute 'has_key'
fatal: [sw-access1]: FAILED! => {"changed": false, "module_stderr": "Traceback (most recent call last):\
File \"/home/labadmin/.ansible/tmp/ansible-local-10451VX2f6D/ansible-tmp-1573554454.14-69301531100280/AnsiballZ_aoscx_vlan.py\", line 102, in <module>
_ansiballz_main()
File \"/home/labadmin/.ansible/tmp/ansible-local-10451VX2f6D/ansible-tmp-1573554454.14-69301531100280/AnsiballZ_aoscx_vlan.py\", line 94, in _ansiballz_main
invoke_module(zipped_mod, temp_path, ANSIBALLZ_PARAMS)
File \"/home/labadmin/.ansible/tmp/ansible-local-10451VX2f6D/ansible-tmp-1573554454.14-69301531100280/AnsiballZ_aoscx_vlan.py\", line 40, in invoke_module
runpy.run_module(mod_name='ansible.modules.aoscx_vlan', init_globals=None, run_name='__main__', alter_sys=False)
File \"/usr/lib/python2.7/runpy.py\", line 192, in run_module
fname, loader, pkg_name)
File \"/usr/lib/python2.7/runpy.py\", line 72, in _run_code
exec code in run_globals
File \"/tmp/ansible_aoscx_vlan_payload_CU2cXY/ansible_aoscx_vlan_payload.zip/ansible/modules/aoscx_vlan.py\", line 146, in <module>
File \"/tmp/ansible_aoscx_vlan_payload_CU2cXY/ansible_aoscx_vlan_payload.zip/ansible/modules/aoscx_vlan.py\", line 106, in main
File \"/tmp/ansible_aoscx_vlan_payload_CU2cXY/ansible_aoscx_vlan_payload.zip/ansible/module_utils/aoscx_vlan.py\", line 29, in create_vlan
", "module_stdout": "", "msg": "MODULE FAILURE
See stdout/stderr for the exact error", "rc": 1}
I have tried this with the role installed from Github and from Ansible Galaxy. I have tried to remove the role and re-install it. It always gave me the error above.
I ran a tcpdump and the ansible host is not even attempting to connect to the target system, so something seems wrong with my local installation.
Any clues on what I'm missing?
