Wired Intelligent Edge
AOS-CX Simple Steps to Deploy VOIP!
This thread has been viewed 175 times
  • 1.  AOS-CX Simple Steps to Deploy VOIP!
    Posted Aug 09, 2020 01:48 AM
    Good day!
    AOS-CX VOIP Deployment simple steps!
    Prior condition or prerequisite (not mandatory):
    • Good know Power over Ethernet (PoE), LLDP, CDP, VLANs.
    • Good know about Voice VLAN and it's Significance.
    • Good know Local User Roles, Downloadable User Roles.
    Pre-Checklist:
    • Check CX operating system version
      • BLDG01-F1# show version
    • Verify Connectivity Check
      • show lldp neighbor-info or show CDP neighbor-info
    • Before starting VOIP deployment, verify voice vlan assignment.
      • BLDG01-F1(config)# vlan 10
        BLDG01-F1(config-vlan-10)# voice
      • BLDG01-F1# show lldp neighbor-info 2/1/3
    Note: Enabling Voice on Vlan context is must for CX VOIP deployment.
    Flow of SIMPLE CX VOIP Deployment:
    • Use Case 1: With Local authentication using local mac match, device-profile
    • Use Case 2: With Remote AAA authentication using radius-attribute
    • Use Case 3: With Remote AAA authentication using Local User Role
    • Use Case 4: With Remote AAA authentication using Downloadable User Role (due to character limits 30,000...added details in attached document)
    Step1:Configure local mac match and device profile as below.
    BLDG01-F1# show running-config mac-group
    mac-group localmacauth
         seq 10 match mac 00:04:f2:80:23:57
    BLDG01-F1# show running-config port-access
    port-access role localmacauthrole
        mtu 1600
        reauth-period 5
    port-access device-profile localauthdp
        enable
        associate role localmacauthrole
        associate mac-group localmacauth
    BLDG01-F1#
    Step2: Enable authentication on interface connected to Phone.
    interface 2/1/3
        no shutdown
        no routing
        vlan trunk native 1
        vlan trunk allowed 10
        spanning-tree port-type admin-edge
        aaa authentication port-access allow-cdp-bpdu
        aaa authentication port-access allow-lldp-bpdu
        aaa authentication port-access client-limit 2
        port-access security violation action shutdown
        aaa authentication port-access dot1x authenticator
            max-eapol-requests 3
            max-retries 1
            reauth
            enable
        aaa authentication port-access mac-auth
            cached-reauth
            cached-reauth-period 86400
            quiet-period 30
            enable
        exit
    BLDG01-F1# show port-access clients
    Port Access Clients
    Port     MAC Address       Onboarded      Status      Role
                               Method
    2/1/3    00:04:f2:80:23:57 device-profile Success     localmacauthrole
    BLDG01-F1#
    BLDG01-F1# sh port-access clients detail
    Port Access Client Status Details:
    Client 00:04:f2:80:23:57
      Session Details
        Port         : 2/1/3
        Session Time : 558s
        IPv4 Address :
        IPv6 Address :
      Authentication Details
        Status          : Authenticated
        Auth Precedence : dot1x - Authenticating, mac-auth - Unauthenticated
      Authorization Details
        Role   : localmacauthrole
        Status : Applied
    Role Information:
    Type  : local
        Reauthentication Period             : 5 secs
        Authentication Mode                 :
        Session Timeout                     :
        Client Inactivity Timeout           :
        Description                         :
        Gateway Zone                        :
        UBT Gateway Role                    :
        Access VLAN                         :
        Native VLAN                         :
        Allowed Trunk VLANs                 :
        Access VLAN Name                    :
        Native VLAN Name                    :
        Allowed Trunk VLAN Names            :
        MTU                                 : 1600
        QOS Trust Mode                      :
        STP Administrative Edge Port        :
        PoE Priority                        :
        Captive Portal Profile              :
        Policy                              :
    BLDG01-F1#
    Note: Authentication default order on AOS-CX is dot1x, mac-auth and then local mac match device-profile. You can always change the order of authentication.
    Use case 2: authenticate phone using AAA radius server.
    Step1: Make sure radius connectivity to switch is proper
    BLDG01-F1# show radius-server detail
    ******* Global RADIUS Configuration *******
    Shared-Secret: None
    Timeout: 5
    Auth-Type: pap
    Retries: 1
    TLS Timeout: 5
    Tracking Time Interval (seconds): 60
    Tracking Retries: 3
    Tracking User-name: radius-tracking-user
    Tracking Password: None
    Number of Servers: 1
    ****** RADIUS Server Information ******
    Server-Name              : aoss-cppm.tmelab.net
    Auth-Port                : 1812
    Accounting-Port          : 1813
    VRF                      : mgmt
    TLS Enabled              : No
    Shared-Secret            : AQBapdAz4irjSK61Zg/CFArsNYWKbn1LObqDD/v9SH1eMQ6ABQAAADY26liu
    Timeout (default)        : 5
    Retries                  : 5
    Auth-Type (default)      : pap
    Server-Group (default)   : radius
    Default-Priority         : 1
    Tracking                 : enabled
    Tracking-Mode            : any
    Reachability-Status      : reachable
    ClearPass-Username       : admin
    ClearPass-Password       : AQBapYv/u3/YfG9vYRpFxmOTtsFLIWxuAX442RdG9j11jsZ6CQAAACZ5Y2/BK9FmhQ==
    BLDG01-F1#
    Note: In this demonstration I am using clearpass as Radius-server, you can use any other radius-server such Cisco ISE or free radius.
    Step2: Enable authentication on the interface.
    BLDG01-F1# show running-config interface 2/1/3
    interface 2/1/3
        no shutdown
        no routing
        vlan trunk native 1
            max-retries 1
            reauth
            enable
            cached-reauth
            quiet-period 30
            enable
        exit
    BLDG01-F1#
    BLDG01-F1# show port-access clients detail
    Client 00:04:f2:80:23:57, 0004f2802357
      Session Details
        Port         : 2/1/3
        Session Time : 75s
        IPv4 Address :
        IPv6 Address :
        Status          : mac-auth Authenticated
        Auth Precedence : dot1x - Unauthenticated, mac-auth - Authenticated
        Role   : RADIUS_773420618
        Status : Applied
    Role Information:
    Type  : radius
        Session Timeout                     :
        Description                         :
        Gateway Zone                        :
        UBT Gateway Role                    :
        Access VLAN                         :
        Native VLAN                         :
        Access VLAN Name                    :
        Native VLAN Name                    :
        MTU                                 :
        QOS Trust Mode                      :
        PoE Priority                        :
        Policy                              :
    BLDG01-F1#
    BLDG01-F1# show vlan port 2/1/3
    VLAN  Name                            Mode            Mapping
    10    VLAN10                          trunk           port
    BLDG01-F1#
    BLDG01-F1# sh lldp neighbor-info 2/1/3
    Port                           : 2/1/3
    Neighbor Entries               : 1
    Neighbor Entries Deleted       : 1
    Neighbor Entries Dropped       : 0
    Neighbor Entries Aged-Out      : 1
    Neighbor Chassis-Name          : Polycom VVX 500
    Neighbor Chassis-Description   : Polycom;VVX-VVX_500;3111-44500-001,7;SIP/4.1.2.25646/13-Feb-13 17:14;UP/5.1.2.0869/13-Feb-13 17:28;
    Neighbor Chassis-ID            : 0.0.0.0
    Neighbor Management-Address    :
    Chassis Capabilities Available : Bridge, Telephone
    Chassis Capabilities Enabled   : Bridge, Telephone
    Neighbor Port-ID               : 00:04:f2:80:23:57
    Neighbor Port-Desc             : 1
    Neighbor Port VLAN ID          :
    TTL                            : 120
    Neighbor PoE information       : MED
    Neighbor Power Type            : PD
    Neighbor Power Priority        : Unknown
    Neighbor Power Source          : BOTH
    PD Requested Power Value       : 8.0 W
    PSE Allocated Power Value      : 8.0 W
    Neighbor MED Capabilities
    Neighbor Device class          : CLASS_III
    MED capabilities enabled       : Capabilities, Network Policy, PD, Inventory
    MED capabilities supported     : Capabilities, Network Policy, PD, Inventory
    Neighbor Med Network Policy
    Neighbor Med Application type  : voice
    Neighbor Med Policy VLAN ID    : 10
    Neighbor Med Policy Priority   : 5
    Neighbor Med Policy DSCP       : 46
    Neighbor Med Policy Unknown    : false
    Neighbor Med Policy Tagged     : true
    Neighbor Med Application type  : voice-signaling
    Neighbor Med Policy DSCP       : 44
    Neighbor Mac-Phy details
    Neighbor Auto-neg Supported    : true
    Neighbor Auto-Neg Enabled      : true
    Neighbor Auto-Neg Advertised   : 1000 BASE_TFD, 100 BASE_TXFD, 100 BASE_TX, 10 BASET_FD, 10 BASE_T
    Neighbor MAU type              : 1000 BASETFD
    BLDG01-F1#
    Note: For Pre-standard Phone, enable below command on interface.
    BLDG01-F1(config-if)# power-over-ethernet pre-std-detect
    Use case 3: VOIP deployment using Local User Role (LUR)
    Step1: Configure local user role
    port-access role phone_role
        auth-mode client-mode
    interface 2/1/3
        no shutdown
        no routing
        vlan trunk native 1
        vlan trunk allowed all
            max-retries 1
            reauth
            enable
            cached-reauth
            quiet-period 30
            enable
        exit
    BLDG01-F1#
    Step2: On radius-server make sure same role name is configured and phone is authenticated.
    Port Access Clients
                               Method
    2/1/3    00:04:f2:80:23:57 mac-auth       Success     phone_role
    BLDG01-F1#
    BLDG01-F1# show port-access role
    Role Information:
    Type  : local
        Authentication Mode                 : client-mode
        Session Timeout                     :
        Description                         :
        Gateway Zone                        :
        UBT Gateway Role                    :
        Access VLAN                         :
        Native VLAN                         :
        Allowed Trunk VLANs                 : 10
        Access VLAN Name                    :
        Native VLAN Name                    :
        MTU                                 :
        QOS Trust Mode                      :
        PoE Priority                        :
        Policy                              :
    BLDG01-F1#
    Use case 3: VOIP Deployment using Download User Role.
    Below Simple references will help during CX VOIP deployment also:
    Have a nice day!
    Yash
    Attachment(s)
    docx
    CX_VOIP_Deployment.docx   916 KB 1 version
  • 2.  RE: AOS-CX Simple Steps to Deploy VOIP!
    Posted Sep 29, 2023 05:10 PM
    I am having a hard time with this on a AOS CX 6100 24G on PL.10.12.1000
    How about a basic example without authentication?
    Will the port remain as an access vlan with no other configurations and and IP phone with LLDP/CDp will boot into Voice vlan and the vlan be assigned to the port automatically?
