Wired Intelligent Edge
AOS-Switch and Cisco IP Phones PoC - Testing CDP, Voice VLAN, QoS, and 802.1X
This thread has been viewed 32 times
  • 1.  AOS-Switch and Cisco IP Phones PoC - Testing CDP, Voice VLAN, QoS, and 802.1X
    Posted May 29, 2019 08:26 PM
    Hello Airheads community
    I had the opportunity to work in a PoC to demonstrate that Aruba AOS-switches fully support a Cisco telephony solution; here are the 5 tasks requested by End Customer and the results achieved (below).
    I also attached the PoC-guide.pdf to this post that shows configurations made in 2930F Switch, Clearpass and CUCM, debugs, show commands, and Access Tracker.
    Topology:
                                                  Image 1
    Task No 1: Turn on Cisco phone 7960. These Cisco phones are very old (currently are EoS/EoL), they have the singularity of supporting the Cisco Pre-standard PoE and CDP (they do not support standard PoE, nor LLDP).
    Result: Aruba 2930F was able to turn on the Cisco Phone 7960, assign the voice VLAN via CDP (Image 2).
    Aruba switches supports these type of phones by entering two commands:
    2930F-8(config)# cdp mode pre-standard-voice
    2930F-8(config)# power-over-ethernet pre-std-detect ports 1-8
                                               Image 2
    Task No 2: Register Cisco Phone 7960 (SCCP) and Cisco Phone 7821 (SIP) phones to CUCM.
    Result: Both phones were able to connect and register to CUCM (Image 3).
    Configuring voice VLANs separates voice traffic from data traffic. You must configure the port as a tagged member of the voice VLAN.
    2930F-8(config)# vlan 50
    2930F-8(vlan-50)# name "Voice"
    2930F-8(vlan-50)# tagged 1
    2930F-8(vlan-50)# ip address 10.10.0.1 255.255.255.0.
    2930F-8(vlan-50)# voice
    2930F-8(vlan-50)# dhcp-server
    2930F-8(vlan-50)# exit
    Per Cisco requirements, you may need to enable DHCP Option 150 so that in the DHCP broadcasts, phones see a list of all TFTP (CUCM) servers that are connected to the network.
    2930F-8(config)#dhcp-server pool "VOICE"
    2930F-8(VOICE)#default-router "10.10.0.1"
    2930F-8(VOICE)#dns-server "8.8.8.8"
    2930F-8(VOICE)#network 10.10.0.0 255.255.255.0
    2930F-8(VOICE)#option 150 ip "172.16.0.90"
    2930F-8(VOICE)#range 10.10.0.5 10.10.0.20
    2930F-8(VOICE)#exit
                                              Image 3
    Task No 3: Authenticate old phones that dont include a Manufacturing Installed Certificate (MIC), such as the 7960, via MAC-AUTH process, and authenticate the most recent phones, such as the 7821, via EAP-TLS using the MIC.
    Result: Both phones were authenticated (Image 5).
    Import Cisco Root certificates to Clearpass in order to execute 802.1X EAP-TLS Authentication Method.
                                               Image 4
    Phones were authenticated via MAC-AUTH (7960) and 802.1X EAP-TLS (7821) and received the VOICE-ROLE:
                                               Image 5
    Task No 4: Assign differentiated network access policies: restrictive access policy to Cisco IP Phones (VOICE-ROLE) and unrestricted access to employees (EMPLOYEE-ROLE).
    Result: Phones and End Users were authenticated, differentiated network access policies were assigned using roles on 2930F switch (image 6).
                                                    Image 6
    Task No 5: Clear the session when the device (PC) is disconnected from the Phone's switch port .
    Result: If the device unplugs from behind the phone, the switch cannot rely on link state to know when to clear the session. Proxy EAPoL-Logoff enables the phone to transmit an EAPoL-Logoff message on behalf of the data device when the phone detects that an 802.1X device has unplugged from behind the phone. AOS-Switch processed the EAPoL-Logoff message and cleared the session. (image 7).
                                                     Image 7
    Task No 6: Assign QoS to voice traffic: tag RTP packects.
    Result: Packet capture showed RTP packets tagged with CoS 5 and DSCP 46 (Image 8).
                                                              Image 8
    Adolfo
    Attachment(s)
    pdf
    PoC-guide.pdf   17.43 MB 1 version
  • 2.  RE: AOS-Switch and Cisco IP Phones PoC - Testing CDP, Voice VLAN, QoS, and 802.1X
    Posted Aug 08, 2019 01:07 PM
    Version 16.08.0005
    https://support.hpe.com/hpsc/doc/public/display?docId=a00079541en_us
    802.1X CR_0000250258 Symptom: User role changes to mac-auth initial role even though the user is not reachable. Scenario: When authenticating a user through 802.1X, if auth-order and auth-priority are configured as authenticator mac-based, the user role changes to mac-auth initial role even after disconnecting the user.
