last person joined: 4 hours ago
AP-304 will not boot.
This thread has been viewed 34 times
  • 1.  AP-304 will not boot.
    Posted Feb 27, 2022 04:18 PM
    I have an AP-304
    It is not booting right. It goes into Kernal Panic and reboots.
    I have attached the console session as a text file.
    Any thoughts on what is happening?
    Is it the Firmware? How do I upgrade firmware through console?
    Thank You
    Michael Shuman
    Attachment(s)
    txt
    Aruba 304.txt   31 KB 1 version
  • 2.  RE: AP-304 will not boot.
    Posted Feb 28, 2022 03:41 AM
    Hi Michael.
    I described an upgrade procedure for AP if the OS image is broken or missing in this thread. AP-325 Missing OS Image
    Best, Gorazd
    Gorazd Kikelj
  • 3.  RE: AP-304 will not boot.
    Posted Mar 22, 2022 01:56 PM
    I have been busy and just comming back to this. but the AP is to be used as an IAP and I do not have a controller.
    Not sure how to send firmware directly to the AP.
    Michael Shuman
  • 4.  RE: AP-304 will not boot.
    Posted Mar 23, 2022 02:26 AM
    It's the same principle. Put Aruba Instant image of your choice for platform Hercules to TFTP server and use upgrade os command to transfer it to AP.
    for example your tftp server ip address is 10.0.0.10 and your image file is ArubaInstant_Hercules_8.9.0.3_83448 then you can upload the file as follows
    boot> setenv serverip 10.0.0.10
    boot> upgrade os 0 ArubaInstant_Hercules_8.9.0.3_83448
    boot> boot
    Hope this help, Gorazd
    Gorazd Kikelj
  • 5.  RE: AP-304 will not boot.
    MVP
    Posted Mar 23, 2022 08:45 AM
    As far as I am aware, you cannot convert AP-304 to IAP. You need an IAP-304. The IAP-304 can ve converted to a Campus AP, if desired.
    Bruce Osborne ACCP ACMP
    Liberty University
    The views expressed here are my personal views and not those of my employer
  • 6.  RE: AP-304 will not boot.
    Posted Mar 23, 2022 08:58 AM
    You can convert AP to IAP with controller if you have ArubaOS 8.6 or higher. This was discussed in different thread.
    Best, Gorazd
    Gorazd Kikelj
