You can't really do that. You could put a 'terminator' on the unused antenna connector, which will have a similar effect and avoid damage to the AP or radio.
There is some guidance
here, and you should get a 50Ohm RP-SMA Terminator.
Original Message:
Sent: Jun 22, 2022 06:51 AM
Subject: AP-504 how to deactivate one A1 Ant Port
i have a customer ( AP-504) wich wants to deactivate 1 off the Antenna Ports A1 should be deactivated.
Is this possible if so how can it be deactivated.
Sven
