AP387 Point 2 Point - no Traffic between Aps and 6G eint come up
  • 1.  AP387 Point 2 Point - no Traffic between Aps and 6G eint come up
    Posted Jan 14, 2022 05:43 PM
    I am a Bit desperate.
    I got two 387.
    Mesh Point should create a Uplink for a Switch through 6g.
    Switches on both sides are 5130 with Trunk Configuration on the AP uplinks.
    A few Minute it Worked...But now:
    On both sides I can reach the APs through IP.
    But only the 5Ghz Channel is established.
    And I am unable to ping Mesh Point through Portal and vise versa.
    No 60Ghz and no traffic. Regardless What I Do and how often I reboot.
    I played around with native vlan (because read a out issues with that).
    What could be my Problem?
    How should I ise "Management vlan id" and Whats the beste Switch Port config (Trunk with native or Hybrid with untagged Management vlan)
    I used 8.7 and know have 8.7
    Does not affect the Problem.
    Thank you
    Marcel Hausmann
  • 2.  RE: AP387 Point 2 Point - no Traffic between Aps and 6G eint come up
    Posted Jan 15, 2022 06:02 PM
    60GHz needs very clean and clear line of sight. Tree branches in the way will definitely kill 60G signal for the AP-387.  so check if you have clear line of sight perhaps that's why you only have 5G mesh.
    you can use "show ap mesh link" to see the status of the two radios.
    here is the configuration tutorial which is a it dated but still good.
    https://community.arubanetworks.com/t5/Controllerless-Networks/Configuring-AP-387-for-Point-to-Point-link/m-p/554115
  • 3.  RE: AP387 Point 2 Point - no Traffic between Aps and 6G eint come up
    Posted Jan 18, 2022 05:41 AM
    Have you seen this discussion? Think it has a lot of good info.
