Cloud Managed Networks
Forum to discuss all things Aruba Central and UXI Network Management, this includes Aruba Central managed networks, Central configuration, best practices, Central APIs, Cloud Guest, AIOps, Presence Analytics and Other Central Applications
Better way to rename APs??
This thread has been viewed 41 times
  • 1.  Better way to rename APs??
    Posted Dec 13, 2022 02:44 PM
    We are migrating from on-prem Airwave to Aruba Central, and I'm finding some UI things to be so unintuitive.
    I have a new access point that has the default MAC address name.  I can search for the MAC address of the AP, and when I click on the AP itself I get a lot of information about it, with no obvious way to rename it.  This would be an ideal place for an edit button.
    Instead, I go through the too-many-clicks process of changing to the group, clicking Devices, then Config, then Access Points.  I now see a list with hundreds (soon to be thousands) of access points.  There is no way to filter or sort this list at all.  How do I find my one new access point without having to endlessly scroll and wait as the list has to continuously keep loading in small increments.
    There HAS to be an easier way, right...?
  • 2.  RE: Better way to rename APs??
    Posted Dec 13, 2022 05:18 PM
    renaming of the APs are done from the group-> config-> Access Points
    there you can filter
    Also note that you have access to Aruba Central API automation site that provides a lot or automation for deployment, like renaming of the APs, etc.
    https://community.arubanetworks.com/discussion/aruba-central-api-automation-site
  • 3.  RE: Better way to rename APs??
    Posted Dec 14, 2022 09:38 AM
    Thanks for the quick reply.  This is interesting, because I believe I am in the same location as you, however I do not have any filter icons in my columns.  I also have a different set of columns available to me in that view, but maybe that is unrelated.
  • 4.  RE: Better way to rename APs??
    Posted Dec 14, 2022 05:08 PM
    just use a different browser or run it in incognito mode and see if it make a different.
  • 5.  RE: Better way to rename APs??
    Posted Dec 15, 2022 09:47 AM
    Same result - I still cannot filter columns.
  • 6.  RE: Better way to rename APs??
    Posted Dec 15, 2022 11:04 AM
    I'm with you, Eric...I don't have that filter option either, and when we first setup our environment, it was ridiculous having to scroll through to find the new AP in that long list. And we only have ~700 APs...I can't imagine what that would be like with thousands!
  • 7.  RE: Better way to rename APs??
    Posted Dec 15, 2022 12:00 PM
    Looks like it will change with Central 2.5.6. Check here for a similar discussion (about the same AP list in Configuration mode)
  • 8.  RE: Better way to rename APs??
    Posted Dec 15, 2022 12:06 PM
    Our vendor gave us the tip that if you change the focus to a single VC (rather than an entire group), you can also rename APs with potentially a much shorter list to scroll through.
    I don't think it would be as frustrating if it didn't feel like a step backwards from what we were used to with Airwave.
