Can't reinstall Aruba Via W10
  • 1.  Can't reinstall Aruba Via W10
    Posted Jul 24, 2019 03:44 AM
    When I reinstall VIA (3.4) on my laptop (W10) it gives me an error. I've tried to find any info at Airheads and I've changed MaxNumFilters in regedit as one article suggests but that's not the problem.
    Anyone with the same issue that could solve it?
    Thanks!!
    Jorge
  • 2.  RE: Can't reinstall Aruba Via W10
    Posted Jul 24, 2019 06:51 AM
    You didn't say what error you are getting....
  • 3.  RE: Can't reinstall Aruba Via W10
    Posted Jul 24, 2019 07:02 AM
    You're right!!
    The errors I've found in the aninst file are:
    ERROR aninsthelper 394 unabel to get the Adapter ((null)), close and exit 0
    ERROR anvainstall 58 UpdateFn failed!
    ERROR aninsthelper 1699 ANVAInstall error -1
    I attach the aninst if you need more info
    Thanks!!
    Jorge
    Attachment(s)
    txt
    aninst.txt   46 KB 1 version
  • 4.  RE: Can't reinstall Aruba Via W10
    Posted Jul 24, 2019 07:19 AM
    Do you have any old version Aruba VIA installed on your Windows PC, if YES uninstall and try again and also check if drivers of your PC is up to date, I see below message in log
    Jul 23 09:40:27.721 p4472 t260c ERROR aninsthelper 394 unabel to get the Adapter ((null)), close and exit 0
    Jul 23 09:40:27.722 p4472 t260c INFO aninsthelper 1665 ANGetVADriverVersion returned 8, version=
    Jul 23 09:40:27.722 p4472 t260c INFO aninsthelper 1668 VA Driver needs to be installed/upgraded
    Jul 23 09:40:27.722 p4472 t260c INFO aninsthelper 712 ANVaInstall enter
    Jul 23 09:40:27.722 p4472 t260c INFO aninsthelper 597 GetServiceInfPath return C:\Program Files\Aruba Networks\Virtual Internet Agent\\arubavnic.inf
    Jul 23 09:40:27.732 p4472 t260c INFO anvainstall 31 InfPath C:\Program Files\Aruba Networks\Virtual Internet Agent\arubavnic.inf
  • 5.  RE: Can't reinstall Aruba Via W10
    Posted Jul 24, 2019 08:30 AM
    Hi!
    I uninstalled it yesterday, is there anything that should be removed manually?
    And I've just upgraded all the drives using the support assistant but I still can't install via.
    Is there any extra info I can send you?
    Thanks!
  • 6.  RE: Can't reinstall Aruba Via W10
    Posted Jul 24, 2019 12:21 PM
    Are you seeing issue on this particular windows machine or all windows 10 PCs?
  • 7.  RE: Can't reinstall Aruba Via W10
    Posted Jul 24, 2019 12:55 PM
    There are no other W10 laptops. I can't install almost anything in my company laptop, so this is a lab laptop...
  • 8.  RE: Can't reinstall Aruba Via W10
    Posted Jul 26, 2019 05:29 AM
    Solved. I did two things
    - Update W10 (no drivers, the OS)
    - Remove laptop from domain (i used it just for testing, it is not necessary)
    Thanks for your help!
