Clearpass Guest active sessions
  • 1.  Clearpass Guest active sessions
    Posted Oct 17, 2013 12:40 PM
    Hi all ,
    Enabled Insight on CPPM but can´t check active sessions on clearpass sessions:
    There are no sessions to display."
    On Aruba controller the guest client shows up  good
    Shoudn´t this one also be showned on Active sessions?
    Another thing is.. Can I put a background image on Captive portal page in ClearPass guest  we login??
    Regards
    86587693iPhone40:a6:d9:3e:52:2410.100.128.1guestCaptive Portal
    Guest_CPPM
  • 2.  RE: Clearpass Guest active sessions
    Posted Oct 17, 2013 01:53 PM
    Did you enable radius accounting in the AAA profile on the Aruba Controller?  Just put the same server group into the radius accounting server group on the controller.
  • 3.  RE: Clearpass Guest active sessions
    Posted Oct 17, 2013 04:37 PM
    As for the background image
    The Custom Skin included allows for personalizing all aspects of the Guest presentation layer. But you need to code up your own CSS with the background itself uploaded via Content Manager.
    Some header or footer text area will need something along the lines of:
    {literal}
    <style type="text/css">
    BODY {
        background: #fff url(public/my-background.png) repeat-x;
    </style>
    {/literal}
    Reference for CSS help http://www.w3schools.com/css/css_background.asp
  • 4.  RE: Clearpass Guest active sessions
    Posted Oct 17, 2013 07:42 PM
    @cjoseph
    I will check tomorrow.. I remmember setting up somd kind of that setting...
    @tarnold
    I already seen that is code based.. I need to learn s little bit... I have setup a month ago a captive portal page on aruba controller. Is ir possible to import that design or clearpass only permit custom skin customization by "hand".
    Thanks you guys.
    Regards
  • 5.  RE: Clearpass Guest active sessions
    Posted Oct 18, 2013 12:20 PM
    Hi
    Active sessions working :)
    Regarding clearpass web login page where do I Put the image ? Content manager is on Clearpass?
    REgards
  • 6.  RE: Clearpass Guest active sessions
    Posted Oct 18, 2013 05:25 PM
    Content Manager is on ClearPass
    ClearPass Onboard > Configuration > Content Manager
     Upload your image there.
    Then inside your code just point to the image.
    img src="public/images/<path to image>"
     I created an "images" directory under the Content Manager so you can ignore that part.
    But the path starts in "public/"
    Cheers
  • 7.  RE: Clearpass Guest active sessions
    Posted Oct 21, 2013 11:29 AM
    Is it for somehow possible to copy the captive portal design that is already created in Aruba and put it on ClearPass?
    Because I already have in the controller a captive portal with the client JPG..
    Regards
  • 8.  RE: Clearpass Guest active sessions
    Posted Oct 21, 2013 12:34 PM
    You would need to rebuild it in ClearPass. CP Guest uses a template engine.
  • 9.  RE: Clearpass Guest active sessions
    Posted Oct 21, 2013 05:36 PM
    Hi, So its pure HTML editing under the custom skin correct?
  • 10.  RE: Clearpass Guest active sessions
    Posted Oct 21, 2013 09:39 PM
    If you want to use your own background then you its done in html with CSS formating.
    https://afp.arubanetworks.com/afp/index.php/How-To:_Custom_Skin_HTML_tips
  • 11.  RE: Clearpass Guest active sessions
    Posted Oct 21, 2013 09:46 PM
    One note is that you can change a of the format setting in the plugin manager.
  • 12.  RE: Clearpass Guest active sessions
    Posted Oct 22, 2013 07:45 AM
    Hi Guys,
    I can´t put a background image on my guest portal on Clearpass.
    It should be a simple thing no?
    Regards
    Please check attach to see what am I doing wrong
    Attachment(s)
    docx
    mne.docx   127 KB 1 version
  • 13.  RE: Clearpass Guest active sessions
    Posted Oct 22, 2013 11:19 AM
    beconnect,
    Somehow We cannot open your docx file.  Can you repost?
  • 14.  RE: Clearpass Guest active sessions
    Posted Oct 22, 2013 11:53 AM
    Sorry.. where it goes
    Regards
    Attachment(s)
    docx
    Doc1.docx   165 KB 1 version
  • 15.  RE: Clearpass Guest active sessions
    Posted Oct 22, 2013 12:01 PM
    Did you check the ACTUAL URL in Content Manager?
  • 16.  RE: Clearpass Guest active sessions
    Posted Oct 23, 2013 05:52 AM
    Hi guys,
    Almost there... Errrr so bad my knowledge in HTML..
    I already set the background as you can see in the attach ( contains the code and the preview of the guest page).
    I need to have the page as full screen
    Could you help?
    Regards
    Attachment(s)
    docx
    mne.docx   1.38 MB 1 version
  • 17.  RE: Clearpass Guest active sessions
    Posted Oct 23, 2013 07:33 AM
    It looks like you set your background using this.
    Check this page out
    I just did a quick Google search and it has some examples of how to make your BG image full screen.
    Someone else here with better knowledge of css/html might have simpler way of doing it though.
    Cheers
  • 18.  RE: Clearpass Guest active sessions
    Posted Oct 24, 2013 05:28 AM
    Bourne,
    thanks. I will try this tomorrow..  It seems that it goes to work fine :)
    I will let you know. Regards
  • 19.  RE: Clearpass Guest active sessions
    Posted Oct 25, 2013 07:40 AM
    work like a charm
    thanks you guys ;))
  • 20.  RE: Clearpass Guest active sessions
    Posted Oct 25, 2013 08:26 AM
    Outstanding!
    Cheers
  • 21.  RE: Clearpass Guest active sessions
    Posted Oct 25, 2013 08:38 AM
    Hi
    IS there any way to put an html page already done direclty in Clear PAss.
    I editied some HTML code with CoffeCup HTML and know ia have a html page to load into CPPM.
    But i only see put the code under web logins on guest manager by hand and it gives me a lot of errors.
    Regards
  • 22.  RE: Clearpass Guest active sessions
    Posted Oct 25, 2013 09:31 AM
    You can upload it under the Content Manager.
    If you wish to use your page though to authenticate users then you would probably have to
    use the "custom form" option for the login page. I believe if you select this option
    though you have to provide all the code to send the username and password to the ClearPass.
    If it is just going to be a simple landing page, then you can just link to it.
