Clearpass Operator login
  • 1.  Clearpass Operator login
    Posted Sep 13, 2017 04:18 PM
    Hi All,
    I am in need of some assistance to setup authentication to Clearpass guest for a receptionist so they only have access to guest.
    This is so they can create guest users for devices that connect to their Aerohive wireless.
    I have created the account in the local user database. I have documented the rest of the configuration for you so you can advise me where I have gone wrong.
    Please see attached.
    Can you please advise me where my configuration has gone wrong?
    I see the correct application service is being hit, but the authentication source, roles or enforcement do not get populated.
    I get this alert on the access tracker:
    [Local User Repository]: Failed to execute sql, reason=ERROR: syntax error at or near test"
    Position: 1"
    Attachment(s)
  • 2.  RE: Clearpass Operator login
    Posted Sep 13, 2017 04:27 PM
    Looks like an SQL error in the local user auth source. Did you modify the [Local User Repository] auth source at all?
  • 3.  RE: Clearpass Operator login
    Posted Sep 13, 2017 04:31 PM
    Also give it a try with the [Admin User Repository]
  • 4.  RE: Clearpass Operator login
    Posted Sep 14, 2017 04:17 AM
    Nope I just created an account under identity > local users section in Clearpass, added username and password and associated a role to the account.
    I did also try the admin user repository but in the access tracker got the error: user not found in admin user repository.
    I got a bit further this morning as I forgot to enable authorization in the service. I enabled this and found that the authorization source has now been populated with local user repository.  However, the roles is still hitting other and enforcement is still default deny access. I still get this error as the alert:
    Position: 1"
    Any other ideas on how to proceed further with this?
  • 5.  RE: Clearpass Operator login
    Posted Sep 14, 2017 04:39 AM
    I have managed to resolve the issue.
    I found the following things that I did not do right initially:
    - Authorization was not enabled on the service.
    - I was logging in with the wrong username for the account that I setup in the local user repository. I was using the name instead of the user-id. Note for the future for me.
  • 6.  RE: Clearpass Operator login
    Posted Feb 01, 2018 08:02 AM
    I have almost similar problem, but is Authorization enabled and login name is ok. Can you please check my configuration ?
    ClearPass version is 6.7.0.35289.
    Attachment(s)
    docx
    CP-Operator.docx   539 KB 1 version
  • 7.  RE: Clearpass Operator login
    Posted Feb 01, 2018 08:15 AM
  • 8.  RE: Clearpass Operator login
    Posted Feb 01, 2018 09:12 AM
    do you have authorization enabled on the service?
  • 9.  RE: Clearpass Operator login
    Posted Feb 01, 2018 09:17 AM
    Yes, Authorization is enabled. As it is in the word file on page 4.
  • 10.  RE: Clearpass Operator login
    Posted Feb 01, 2018 09:40 AM
    oh sorry missed the attachement. Can you send me the summary tab of the access tracker when you try and login?
  • 11.  RE: Clearpass Operator login
    Posted Feb 01, 2018 09:47 AM
    Authorization is successfull. But the admin_privileges parametr is not change. it is still the same as the local user role (test123).
    Summary tab is attached.
