last person joined: 7 hours ago
Cluster IAP-325 and AP-515
  • 1.  Cluster IAP-325 and AP-515
    Posted Jan 27, 2020 10:53 AM
    I'm trying to create a cluster between these two AP.
    I've installed and configured IAP-325 (OS Version :8.5.0.5 (build 73491)) as VC.
    But, when I'm adding AP515 - it's starting and rebooting every 2-3 minutes. I don't have a cable and console access.
    In the IAP 325 UI sometimes I see AP515 in the "monitor" mode and notification, that this AP (515) is down.
    After I'm turning off IAP 325 and restarting 515 I've a full access to AP515 via WebUI. I can see, that it has the same OS version.
    How to throubleshoot this?
    Thanks in advance!
  • 2.  RE: Cluster IAP-325 and AP-515
    MVP EXPERT
    Posted Jan 27, 2020 11:06 AM
    Do you have allowed new APs enabled? Also under the Faults section of the GUI it will tell you why an AP failed to join the cluster. You may need to upgrade the AP515 to 8.5.0.5 prior to introducing it into the AP315 cluster.
    https://www.arubanetworks.com/techdocs/Instant_83_WebHelp/Content/Instant_CLI/allow-new-aps.htm
  • 3.  RE: Cluster IAP-325 and AP-515
    Posted Jan 27, 2020 12:08 PM
    AP515 has exactly the same OS version (I think that image was downloaded from IAP 325).
    I the fault history only one message several times:
    Access point f4:2e:XXXX is down. *(f4:2e - 515 MAC)
  • 4.  RE: Cluster IAP-325 and AP-515
    MVP EXPERT
    Posted Jan 27, 2020 12:31 PM
    SSH to the VC IP and perform a 'show log system', is there any clues in
    there?
  • 5.  RE: Cluster IAP-325 and AP-515
    Posted Jan 27, 2020 12:53 PM
    Here is a log of IAP 325:
    192.168.1.124 - AP 515 (F4: 2E)
    192.168.1.126  - IAP 325 (44:48)
    44:48:X:X:X:X# show log system
    Jan 27 17:02:38 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:03:15 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:04:45 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:06:15 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:06:17 cli[6136]: <341097> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| recv_image_check: mac-f4:2e:7f:c8:ad:f4, version-8.5.0.5-8.5.0.5_73491, cc ode_idx-255.
    Jan 27 17:06:17 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| ccode_index_to_ccode_array_idx_vc, return i = 6
    Jan 27 17:06:17 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| is_reg_domain_match my_arr_idx = 6, other_arr_idx= 6
    Jan 27 17:06:17 cli[6136]: <341165> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| send image match to 192.168.1.124.
    Jan 27 17:06:22 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| recv_drt_check
    Jan 27 17:06:22 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| drt version is the same.
    Jan 27 17:06:32 cli[6136]: <341254> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| VC add delta configuration id 1 to msg CLI_CONFIG_INIT.
    Jan 27 17:06:32 cli[6136]: <341199> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| send_config_init: send config to slave 192.168.1.124, csum 43839, using ur l 0, auto save disable 0.
    Jan 27 17:06:32 cli[6136]: <341102> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| Incorrect format for message type 0:0:1:0:192.168.1.124:24635.
    Jan 27 17:06:45 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:07:45 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:09:15 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:10:45 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:11:36 cli[6136]: <341097> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| recv_image_check: mac-f4:2e:7f:c8:ad:f4, version-8.5.0.5-8.5.0.5_73491, cc ode_idx-255.
    Jan 27 17:11:36 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| ccode_index_to_ccode_array_idx_vc, return i = 6
    Jan 27 17:11:36 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| is_reg_domain_match my_arr_idx = 6, other_arr_idx= 6
    Jan 27 17:11:36 cli[6136]: <341165> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| send image match to 192.168.1.124.
    Jan 27 17:11:41 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| recv_drt_check
    Jan 27 17:11:41 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| drt version is the same.
    Jan 27 17:11:45 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:11:52 cli[6136]: <341254> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| VC add delta configuration id 1 to msg CLI_CONFIG_INIT.
    Jan 27 17:11:52 cli[6136]: <341199> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| send_config_init: send config to slave 192.168.1.124, csum 43839, using ur l 0, auto save disable 0.
    Jan 27 17:11:52 cli[6136]: <341102> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| Incorrect format for message type 0:0:1:0:192.168.1.124:24635.
    Jan 27 17:12:15 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:13:15 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:14:45 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:16:15 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:17:45 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:19:15 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:20:45 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:22:15 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:22:19 cli[6136]: <341097> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| recv_image_check: mac-f4:2e:7f:c8:ad:f4, version-8.5.0.5-8.5.0.5_73491, cc ode_idx-255.
    Jan 27 17:22:19 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| ccode_index_to_ccode_array_idx_vc, return i = 6
    Jan 27 17:22:19 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| is_reg_domain_match my_arr_idx = 6, other_arr_idx= 6
    Jan 27 17:22:19 cli[6136]: <341165> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| send image match to 192.168.1.124.
    Jan 27 17:22:24 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| recv_drt_check
    Jan 27 17:22:24 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| drt version is the same.
    Jan 27 17:22:45 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:23:45 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:25:15 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:26:45 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:28:15 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:29:45 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:31:15 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:31:53 cli[6136]: <341097> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| recv_image_check: mac-f4:2e:7f:c8:ad:f4, version-8.5.0.5-8.5.0.5_73491, cc ode_idx-255.
    Jan 27 17:31:53 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| ccode_index_to_ccode_array_idx_vc, return i = 6
    Jan 27 17:31:53 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| is_reg_domain_match my_arr_idx = 6, other_arr_idx= 6
    Jan 27 17:31:53 cli[6136]: <341165> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| send image match to 192.168.1.124.
    Jan 27 17:31:58 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| recv_drt_check
    Jan 27 17:31:58 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| drt version is the same.
    Jan 27 17:32:08 cli[6136]: <341254> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| VC add delta configuration id 1 to msg CLI_CONFIG_INIT.
    Jan 27 17:32:08 cli[6136]: <341199> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| send_config_init: send config to slave 192.168.1.124, csum 43839, using ur l 0, auto save disable 0.
    Jan 27 17:32:08 cli[6136]: <341102> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| Incorrect format for message type 0:0:1:0:192.168.1.124:24635.
    Jan 27 17:32:15 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:34:45 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:36:15 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:37:45 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:39:15 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:40:45 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:42:15 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:43:45 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:45:15 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:46:24 cli[6136]: <341097> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| recv_image_check: mac-f4:2e:7f:c8:ad:f4, version-8.5.0.5-8.5.0.5_73491, cc ode_idx-255.
    Jan 27 17:46:24 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| ccode_index_to_ccode_array_idx_vc, return i = 6
    Jan 27 17:46:24 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| is_reg_domain_match my_arr_idx = 6, other_arr_idx= 6
    Jan 27 17:46:24 cli[6136]: <341165> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| send image match to 192.168.1.124.
    Jan 27 17:46:29 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| recv_drt_check
    Jan 27 17:46:29 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| drt version is the same.
    Jan 27 17:46:40 cli[6136]: <341254> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| VC add delta configuration id 1 to msg CLI_CONFIG_INIT.
    Jan 27 17:46:40 cli[6136]: <341199> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| send_config_init: send config to slave 192.168.1.124, csum 43839, using ur l 0, auto save disable 0.
    Jan 27 17:46:40 cli[6136]: <341102> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| Incorrect format for message type 0:0:1:0:192.168.1.124:24635.
    Jan 27 17:46:45 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:47:45 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:49:15 cli[6136]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| The DRT version is not newer than current DRT table
    Jan 27 17:49:20 syslog: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli | is_factory_reset_on_running : Swarm quit factory default status by : ssid_con fig
    Jan 27 17:49:26 cli[16073]: <341004> <WARN> |AP 44:48:X:X:X:X@192.168.1.126 cli| is_factory_reset_on_running : Swarm quit factory default status by : ssid _config
  • 6.  RE: Cluster IAP-325 and AP-515
    Posted Jan 27, 2020 01:19 PM
    I've found this solution, but don't understand how to do this and where(
    https://community.arubanetworks.com/t5/Controllerless-Networks/IAP-not-able-to-join-VC/td-p/255715/page/2
    I've resolved the issue.
    After changing the tag settings from untag ap mgmt only to untag all and then back to untag ap mgmt only and a reboot fixed the issue.
    Probably some code got 'stuck' and was solved either after the reboot or after changing the tag setting.
  • 7.  RE: Cluster IAP-325 and AP-515
    Posted Jan 28, 2020 09:38 AM
    there?
    Hi Craig,
    Do you have any ideas for this case?
    I would be very appreciate for your help!!!
