Convert IAP to RAP error (AOS8 + Mobility Master)
  • 1.  Convert IAP to RAP error (AOS8 + Mobility Master)
    Posted Feb 24, 2020 07:50 AM
    I’ve an issue with RAP in a new deployment with two VMM and 1x 7210 Mobility Controller (for now, then I'll add two controllers).
    The problem is when I try to convert an IAP to RAP, the Mobility Controller (MD) is behind a NAT that is configured for the Mobility Controller DMZ IP Address <PUBLIC_IPADDR: 4500> -> <DMZ_IPADDR_MC: 4500>. Firewall can reach the Mobility Controller DMZ IP Address.
    I already configured VPN-POOL, enabled NAT-T, configured “Shared Secret”, RAP Whitelist and also created a local user with an AP-ROLE, but it still doesn't work.
    I see the 4500 UDP port on the Mobility Controller with the command “show datapath session | include 4500”
    But when I run the command “show crypto ipsec sa” I see only Mobility Device session with Virtual Mobility Master.
    I think strange the output below when I ran the command “show log security all”.
    Feb 23 17:53:39 :103063: <3600> <DBUG> |ike| exchange_start_ikev2 pre-connect check duplicate mapname:default-local-master-ipsecmap
    I already have a tunnel established with Virtual Mobility Master, can this be a problem?
    Has anyone experienced this problem?
    I have some environments working with RAP, the only difference in this new scenario are the VMMs.
    Attachment(s)
    txt
    show-log-security.txt   25 KB 1 version
  • 2.  RE: Convert IAP to RAP error (AOS8 + Mobility Master)
    Posted Feb 24, 2020 09:26 AM
    Could you post the output of following commands:
    show vpdn l2tp local pool
    show crypto isakmp sa
    show log system
    show user-table verbose
  • 3.  RE: Convert IAP to RAP error (AOS8 + Mobility Master)
    Posted Feb 24, 2020 10:39 AM
    Hi Ankyt, thanks for replying.
    In addition to the logs you requested I also posted,
    sh log security all
    IAP to RAP convert log error
    Thanks.
    Attachment(s)
  • 4.  RE: Convert IAP to RAP error (AOS8 + Mobility Master)
    Posted Feb 24, 2020 11:56 AM
    I went through the logs and found some error messages in system logs.
    It seems your controller is in disaster recovery mode and there is a config sync issue. Please find the logs for the same below:
    Feb 24 12:12:43 cfgm[3524]: <399814> <3524> <DBUG> |cfgm| handle_read: State(READY:CONFIG DISASTER RECOVERY:CFGID-88:PEND-88:INITCFGID:64) FD=33:Ignoring config sync as LC is in Disaster Recovery Mode, masterid=88 myid=88.
    Validate the config sync issue by running command #show switches.
    Please disable the disaster recovery mode if it is enabled. Once disabled again check the controller status by running command #show switches
    Could you please validate the license as well by running command #show ap license-usage
    Please let me know OS version of the controller and IAP.
  • 5.  RE: Convert IAP to RAP error (AOS8 + Mobility Master)
    Posted Feb 24, 2020 08:10 PM
    The Controller was in Disaster Recovery mode, but at the time of the logs it was already in Update Succesfull status.
    Mobility Controller Version: 8.6.0.2_73853
    IAP Version: 8.6.0.2 (build 73853)
  • 6.  RE: Convert IAP to RAP error (AOS8 + Mobility Master)
    MVP GURU
    Posted Feb 24, 2020 01:42 PM
    Have you tried disabling the NAT-T setting and testing again. You shouldn't need to enable that if you're already allowing UDP 4500 and you have the translation setup on your upstream device.
  • 7.  RE: Convert IAP to RAP error (AOS8 + Mobility Master)
    Posted Feb 24, 2020 03:17 PM
    Hi
    Please keep in mind that when you work with a cluster you need to have a different config for the RAPs then without a cluster. I am assuming you are creating a cluster out of the two 7210s.
    Where did you create the VPN pool? At what level?
  • 8.  RE: Convert IAP to RAP error (AOS8 + Mobility Master)
    Posted Feb 24, 2020 08:42 PM
    Hi mrtwentytwo,
    Yes I understand that in the cluster I need to create the vpn pool at the MM level,
    But at the moment I have only 1x 7210 and I haven't configured a cluster, I will configure the cluster only when the second controller arrives at the customer.
    As I don't have a cluster configured, I configured the rap vpn pool at the "Managed Device" level.
  • 9.  RE: Convert IAP to RAP error (AOS8 + Mobility Master)
    Posted Feb 25, 2020 05:39 AM
    Nothing you have configured looks wrong, so far.
    Two suggestions:
    - Try to convert an IAP from "inside" your network first (yes it will work).
    - Open an Aruba Technical Support case in parallel to this post.  http://www.arubanetworks.com/support-services/support-program/contact-support
  • 10.  RE: Convert IAP to RAP error (AOS8 + Mobility Master)
    Posted Feb 24, 2020 08:22 PM
    Hi Dustin-Burns,
    I hadn't tried to disable NAT-T before.
    Next Thursday I will disable NAT-T on Controller and analyze the traffic on the custumer's firewall.
    I update you.
