Delete and unassign IAP in central
  • 1.  Delete and unassign IAP in central
    Posted Dec 17, 2017 04:49 AM
    Hello
    I'm have a silly problem with 2 IPA's, I have deleted them via Network monitoring- Network overview -Ap's.
    What is left now is to unassign them so they wont check in to central again, but I cant seem to figure out how.
    Please advice.
    //regards
    Andreas
  • 2.  RE: Delete and unassign IAP in central
    Posted Dec 17, 2017 09:42 PM
    How to remove license( to unmanage IAP)
    Under Maintenance > Device Provisioning > Manage Licenses and Search for the device(s) in question and unassign the license
    How to delete:
    http://community.arubanetworks.com/t5/Controller-less-WLANs/Deleting-details-of-IAP-from-Aruba-Central/ta-p/291887
    Get Outlook for iOS
  • 3.  RE: Delete and unassign IAP in central
    Posted Dec 18, 2017 05:49 AM
    Thank you for the reply Victor.
    The problem is that I can't fint that option under Maintenance at all, I'm lost so to speak :)
    Is it just bad luck or am I looking at the wrong place ?
  • 4.  RE: Delete and unassign IAP in central
    Posted Dec 19, 2017 08:58 PM
    I have same problem.
  • 5.  RE: Delete and unassign IAP in central
    Posted Dec 20, 2017 04:39 AM
    So the solution is :  #drumroll
    Global settings -> Subscription assignment -> Select Devices
    Untick the Ap's that dont need license anymore and select save
    //andreas
  • 6.  RE: Delete and unassign IAP in central
    Posted Dec 20, 2017 08:37 PM
    //andreas
    Hi  Andreas
    I have another question
    After the change IAP management mode will be changed back to local?
    Thanks!
    Hawk
  • 7.  RE: Delete and unassign IAP in central
    Posted Dec 21, 2017 03:10 AM
    Hello Hawk
    Yes it will change back to locally managed after that, well mine did atleast.
    If not, try and run a reset.
    //andreas
  • 8.  RE: Delete and unassign IAP in central
    Posted Dec 21, 2017 03:55 AM
    Hi andreas,
    Thank you!
    Hawk
  • 9.  RE: Delete and unassign IAP in central
    Posted Apr 11, 2018 07:50 AM
    Where do I untick if I want to remoe this AP? I am not using Activate. I deleted it in Maintenace and factory resetted the IAP and it still keeps reconnecting.
  • 10.  RE: Delete and unassign IAP in central
  • 11.  RE: Delete and unassign IAP in central
    Posted Apr 11, 2018 08:05 AM
    Just to be clear on why I want to remove the IAP:
    I used this IAP for an Aruba Central Demo, and since I finished the demo, I want to completely remove it from Central and use it as a standalone Instant AP for a different demi, but it keeps reconnecting to central
    Steps I tried:
    I removed the licence from the IAP in Subscription Assignment.
    Deleted the down IAP in the Monitoring section.
    I factory resetted the IAP.
    And when I plug it back in, it reconnects to Central.
    Any thoughts? :)
