  • 1.  DHCP Issue
    Posted May 11, 2019 05:43 AM
    Hi Peeps,
    Actually I'm facing an issue with Aruba controller 7005, after provisioning my AP 228, I'm not getting DHCP on mobile but on laptop it's working fine.
    Can you advise troubleshooting steps ?
    Thanks & Regards
    Keshav
  • 2.  RE: DHCP Issue
    Posted May 11, 2019 06:22 AM
    Please try to turn on dhcp debugging on your 7005:  https://community.arubanetworks.com/t5/Command-of-the-Day/COTD-Why-is-my-client-NOT-getting-a-DHCP-address/td-p/6825
    Please note in ArubaOS 8.x the format for logging is slightly different than 6.x, so you should use the tab key to autocomplete your commands.
  • 3.  RE: DHCP Issue
    Posted May 11, 2019 07:15 AM
    Hi Joseph,
    Will check that in my office tomorrow.
    Another thing, can dhcp fails because of poE injector not sending enough power ?
  • 4.  RE: DHCP Issue
    Posted May 11, 2019 08:09 AM
    I have never seen that scenario.  That doesn't mean it is not possible.  The dhcp debug would show you if the client is requesting it and if the server is responding.  That is probably the best way to start to narrow it down.
  • 5.  RE: DHCP Issue
    Posted May 12, 2019 05:23 AM
    Today I got another issue.
    After provisioning AP, access point remains red and no ssid is broadcasting.
    (Coldroom) #show user-table verbose
    Users
    IP MAC Name Role Age(d:h:m) Auth VPN link AP name Roaming Essid/Bssid/Phy Profile Forward mode Type Host Name Server Vlan Bwm UaStr:ParseDisable/Flag/ShortIndex
    192.168.151.117 00:00:00:00:00:00 sys-ap-role 00:00:19 TRANSPORT-VPN N/A default-cap tunnel Internal 0 (0) OFF/0/0
    User Entries: 1/1
    Curr/**bleep** Alloc:1/3 Free:0/2 Dyn:1 AllocErr:0 FreeErr:0
    Can you please help.
    Attachment(s)
    txt
    log ap228.txt   6 KB 1 version
  • 6.  RE: DHCP Issue
    Posted May 12, 2019 07:19 AM
    What do you see in the ap table? Are the ap’s connected and placed in the correct group?
  • 7.  RE: DHCP Issue
    Posted May 20, 2019 06:15 AM
    Yes problem solved.
    I bypass poE injector and instead I used my poE switch aruba 2530.
