EIRP AP 515
This thread has been viewed 45 times
  • 1.  EIRP AP 515
    Posted Apr 09, 2021 03:51 AM
    Hello to all,
    I don't understand the following interface:
    If I understand well, Power is well the EIRP? if yes 23 Dbm is well?
    - 92 Dbm in noise is correct? it seems to me that the more the figure moves away from 0 the more it is not good
    Do you have optimizations to advise me for an area with high concentration of wifi (like big city)?
    I thank you
    Sincerely
  • 2.  RE: EIRP AP 515
    MVP GURU
    Posted Apr 09, 2021 07:10 AM
    Yes that would be the EIRP. The closer to -100 for the noise floor the better. You want a large gap between RSSI and Noise.
    For RF best practices I would start here : https://community.arubanetworks.com/blogs/jamie-test1/2019/02/11/rf-and-roaming-optimization-for-aruba-80211ac-networks?CommunityKey=dcc83c62-1a3a-4dd8-94dc-92968ea6fff1
    Dustin Burns
  • 3.  RE: EIRP AP 515
    Posted Apr 09, 2021 07:28 AM
    Thank you for your feedback and the document.
    So if the  EIRP is big ,so  is better?
    Best regards
  • 4.  RE: EIRP AP 515
    MVP GURU
    Posted Apr 09, 2021 07:42 AM
    Not necessarily. You don't want to set the EIRP higher than the max transmit power of your least capable most important (LCMI) device. Think of it like this. I can talk to you across a football field with a megaphone. You can hear me, but if you try to talk back without (lower power), I may not hear you.
    Also, setting EIRP higher can also lead to other issues like CCI or Co-Channel Interference. More than one AP operating in the same space on the same channel.
    Dustin Burns
  • 5.  RE: EIRP AP 515
    MVP GURU
    Posted Apr 09, 2021 07:45 AM
    I would also use this as a guideline to get going. See attached image.
    Dustin Burns
  • 6.  RE: EIRP AP 515
    Posted Apr 09, 2021 07:54 AM
    Thank you for your explanations. I understand better.
    As for your second message, I will apply it right away.
    I have a question for you, if you don't mind, for wifi video (teams type) what parameter should I pay the most attention to?
    I thank you
    lapillo kevin
  • 7.  RE: EIRP AP 515
    MVP GURU
    Posted Apr 09, 2021 08:50 AM
    I would keep an eye on signal quality and device health. You would want good SNR (Signal to Noise Ratio) for WiFi video and audio.
    Dustin Burns
  • 8.  RE: EIRP AP 515
    Posted Apr 09, 2021 09:09 AM
    mmm OK,
    Thank you, I'll look into it
    Thank you again for your help and your answer
    lapillo kevin
