Endpoint Profiler DCHP Fingerprint No Update at Re-Connect Wired MAC-auth
  • 1.  Endpoint Profiler DCHP Fingerprint No Update at Re-Connect Wired MAC-auth
    MVP EXPERT
    Posted May 13, 2018 03:30 PM
    I focus a strange issue in Clearpass 6.7.3.
    When a wired endpoint connect the first time, dhcp fingerprint works correctly, profiling profiled it as computer, do a correct COA session termination.
    But when i remove the endpoint and reconnect the endpoint within 5 minutes DCHP Fingerprint is not received and profiling dont happens.
    I stubble this issue for two weeks now. Google, aruba documentation and other topics here dont give me the answer.
    I hope that some CP experts here can help me with solve this issue.
    See attachment with screenshots and detailed information.
    Attachment(s)
    pdf
    DCHP Fingerprint ISSUE.pdf   905 KB 1 version
  • 2.  RE: Endpoint Profiler DCHP Fingerprint No Update at Re-Connect Wired MAC-auth
    Posted May 13, 2018 04:30 PM
    Devices are not reprofiled within a 5 minute window.
  • 3.  RE: Endpoint Profiler DCHP Fingerprint No Update at Re-Connect Wired MAC-auth
    MVP EXPERT
    Posted May 13, 2018 04:47 PM
    Hi Cappalli,
    Thanks for the quick and clear answer, appreciate your involvement on airheads!
    So... From a hackers mind, it knowns that printer are mostly not accept 802.1x. So i turn off and on a printer, its profiled again as printer (conflict will be true). I reconnect within 5min with my MAC spoofed notebook, and iam in your Printer vlan (without a conflict). Hopefully the printer vlan is protected by the firewall ;)
    Is there some good reason why dhcp profiling only take place once again after 5 minutes. It maybe could a nice feature. I dont think it should take a lot more of resources of CP because it isnt a normal behavior of a normal client.
    Thanks for help me out here!
  • 4.  RE: Endpoint Profiler DCHP Fingerprint No Update at Re-Connect Wired MAC-auth
    MVP EXPERT
    Posted May 13, 2018 04:52 PM
  • 5.  RE: Endpoint Profiler DCHP Fingerprint No Update at Re-Connect Wired MAC-auth
    Posted May 13, 2018 04:58 PM
    Why would a headless network be more privileged than an end user?
  • 6.  RE: Endpoint Profiler DCHP Fingerprint No Update at Re-Connect Wired MAC-auth
    Posted Apr 17, 2019 03:12 AM
    So to confirm, this is not a configurable interval.  I have been experiencing this same issue when converting our devices to MAC Auth Network Access Control.  I will see them fail becuase they don't get profiled, or they fail to import the profile to the endpoint database.  Then I see a number of minutes later that we re-enable NAC and it works like a charm and gets profiled.
    Just seems like an odd limitation.
