Network Management
How can I register Airwave VM Appliance in my hpe portal account
  • 1.  How can I register Airwave VM Appliance in my hpe portal account
    Posted Jan 30, 2019 03:23 AM
    Good Morning,
    one question today about registration airwave vm appliance in my hpe portal.
    in 2018 we´ve instaled airwave with our partner and now I want to upgrade to the last version of airwave but I cannot download the packages from my hpen networking portal because the airwave appliance is not registerd.
    How can I register the airwave vm appliance?
    Greetings
  • 2.  RE: How can I register Airwave VM Appliance in my hpe portal account
    MVP EXPERT
    Posted Jan 30, 2019 04:22 AM
    Have you registered the license first? This will be tied to your support contract and thus the credentials you can use to upgrade the appliance via the Support Center.
    Attachment(s)
  • 3.  RE: How can I register Airwave VM Appliance in my hpe portal account
    Posted Jan 30, 2019 04:37 AM
    I´ve registered the lic at the first installation with my credentials of my networking portal.
    I can see the lice under my licences but not included with software downloads
  • 4.  RE: How can I register Airwave VM Appliance in my hpe portal account
    MVP EXPERT
    Posted Jan 30, 2019 04:44 AM
    And have you used these credentials to attempt the upgrade?
  • 5.  RE: How can I register Airwave VM Appliance in my hpe portal account
    Posted Jan 30, 2019 04:55 AM
    I don´t have internet connection at the airwave appliance so I want to download manually the update files
  • 6.  RE: How can I register Airwave VM Appliance in my hpe portal account
    MVP EXPERT
    Posted Jan 30, 2019 04:57 AM
  • 7.  RE: How can I register Airwave VM Appliance in my hpe portal account
    Posted Jan 30, 2019 05:25 AM
    I don´t have access to download it - my lics are at my networking portal and i must migrat to ASP first.
    It´s really frustrated, I only want to update airwave appliance.
    So I configured my appliance for internet connection but when i want to download the file
    Downloading....
    Error: Could not download requested software from HPE My Networking Portal
  • 8.  RE: How can I register Airwave VM Appliance in my hpe portal account
    MVP EXPERT
    Posted Jan 30, 2019 05:34 AM
    Can you post the full output of the commands you are using? What version
    are you running now and which version do you intend to upgrade to?
  • 9.  RE: How can I register Airwave VM Appliance in my hpe portal account
    Posted Jan 30, 2019 05:44 AM
    my installed version is 8.2.6.1
    login as: ampadmin
    ampadmin@172.16.0.227's password:
    AirWave Management Platform 8.2.6.1 on
      1  Upload File
      2  Download File
      3  Delete File
      4  Backup
      5  Restore
      6  Support
      7  Upgrade
      8  Advanced
      9  Security
     10  Custom Commands
     11  Enter Commands
      q  >> Quit
    Your choice: 7
    Upgrade
      1  Upgrade AirWave Management Platform
      2  Upgrade OS Kernel
      b  >> Back
    Your choice: 1
    Running Upgrade AirWave Management Platform
    Enter desired version: 8.2.8.0
    Upgrade script AMP-8.2.8.0-amp_upgrade was not found in local cache.
    Upgrade package AMP-8.2.8.0-x86_64-cvs.tar.gz was not found in local cache.
    Upgrade package will be downloaded from the internet...
    Do you use proxy server? (y/N): y
    Enter the proxy server address (proxy.myprovider.net): 172.16.0.1
    Enter the proxy port: 8080
    Setting the proxy server to 172.16.0.1:8080.
    Do you use a proxy username/password? (yes/no): n
    Download upgrade package from:
        1. Aruba Support Portal
        2. HPE My Networking Portal
    Enter your choice (1 or 2): 2
    Preparing to connect to HPE My Networking Portal...
    Enter your HPE My Networking Portal username: xxx
    Enter your HPE My Networking Portal password: xxxx
    Downloading....
    If your firewall restricts direct HTTP communication to
    the internet, it is possible to use a HTTP proxy server.
    Enter the proxy details when prompted.
    Hit enter to continue, 's' to show output, 'r' to show return code.
  • 10.  RE: How can I register Airwave VM Appliance in my hpe portal account
    Posted Jan 30, 2019 09:15 PM
    Could you try to use the Aruba portal instead of the HPE for the download?
  • 11.  RE: How can I register Airwave VM Appliance in my hpe portal account
    Posted Jan 31, 2019 02:33 AM
    we migrate hpe networking portal to aruba support portal with help from a a aruba engineer.
    so we could update the airwave appliance
    thanks for your help
