IAP 207 rebooting
  • 1.  IAP 207 rebooting
    Posted Nov 15, 2019 04:57 PM
    Hi
    Any ideas on the below please?
    not sure what else to check?
    Scenario:
    Edge switches - 2530 POE+ 48 ports x9
    Core switches - 5406R x1
    IAP - 207 x51
    firmware: 8.5.0.0
    Management - Aruba Central
    Issue:
    IAP are randomly rebooting across various switches
    reboot reason - AP rebooted caused by cold HW reset(power loss)
    checked: - Please see attached
    PoE usage on the switch
       - lots in reserve
    PoE delivering on the ports
       - delivering as requested by IAP
    Switch is not rebooting
    Cabling guy says his runs are all less that 100meter
    and this cables are all good
    Log on the switch did show this message:
    11/14/19 09:58:42 00563 ports: port 2 PD MPS Absent indication.
    cant find to much information on this other than the device lost power
    Thank you
    Attachment(s)
    txt
    IAP207_issue.txt   2 KB 1 version
  • 2.  RE: IAP 207 rebooting
    Posted Nov 18, 2019 08:42 PM
    perhaps try a cable test on the switch just to make sure.
  • 3.  RE: IAP 207 rebooting
    Posted Nov 26, 2019 02:37 AM
     Hi Matthew
    Thank you, will give that go.
