IAP-277 wont start
  • 1.  IAP-277 wont start
    Posted Aug 24, 2018 01:00 PM
    Hi there,
    Just received a new IAP-277, connected it to the existing Aruba AP and it attempt to start but the status light turn solid red.
    Looking at the file I can see some error but I can't tell what is the issue.
    Help decipehring it will be appreciated.
    Thanks Dov
    Attachment(s)
    docx
    aruba-277.docx   131 KB 1 version
  • 2.  RE: IAP-277 wont start
    Posted Aug 24, 2018 06:46 PM
    What is the other AP(s) that you're trying to connect this IAP-277 with?
    The rest of the Instant cluster are IAP-215s? The cluster is currently running 6.5.4.8?
    It looks like the problem could be insufficient power to the IAP-277:
    Power Status
    Item                        Value
    Power Supply                : POE-AF
    LLDP Power                  : 0.0W
    Current Operational State   : Ethernet port 1 disabled; All radios disabled;
  • 3.  RE: IAP-277 wont start
    Posted Aug 25, 2018 10:41 AM
    Indeed - I changed to POE+ and everything is working as expected.  Thanks Dov
