Wired Intelligent Edge
last person joined: 11 hours ago
JG963A - QoS
This thread has been viewed 37 times
  • 1.  JG963A - QoS
    Posted Jan 20, 2022 10:29 AM
    two tagged VLANs were configured on a JG963A. One VLAN for the intranet and one VLAN for VoIP. I would like to set up QoS rules for the Voip VLAN.
    In the instructions you will find configuration examples for QoS with this description:
    a. From the navigation tree, select QoS > QoS > QoS Policy.
    b. Apply a QoS policy to the incoming traffic of GigabitEthernet 1/0/2.
    I can still select the port in the web interface, "WebVLAN_200_1" is specified for the name of the policy (wherever that comes from), the "Incoming Mode" is unknown to me.
    The following points then follow in the instructions:
    c. Access the details page for the QoS policy to modify the applied QoS policy as follows:
    − Create IPv4 ACL 2000, and add a rule to permit packets with source IP address
    192.168.1.0 and mask 0.0.0.255.
    − Configure the ACL as a match criterion of a class, and specify the associated behavior
    to mark the matched packets with 802.1p priority 0.
    These cannot be found even if I have created a test rule.
    Is there a different guide or a better example?
    Many Thanks.
    greeting
    Mark
    Markus Müller
  • 2.  RE: JG963A - QoS
    Posted Jan 20, 2022 11:10 AM
    Hello Markus,
    Could you please check if the following example is working for you:
    https://community.arubanetworks.com/browse/articles/blogviewer?blogkey=dd8a9837-fda9-4397-9bb3-193c4e2a491c
    Hope this helps!
    -Alex-
  • 3.  RE: JG963A - QoS
    Posted Jan 21, 2022 01:59 AM
    Hello Alex,
    Thank you. This helps me enormously.
    Now I have to create a rule that VLAN200 (Voice) vs. prioritized with the VLAN100 (intranet). In VLAN 200, the phones and the PBX server are on HyperV.
    Hope to find something about this. The example in the operating instructions for the switch is not bad.
    Markus
    Markus Müller
  • 4.  RE: JG963A - QoS
    Posted Feb 28, 2022 06:03 AM
    Hello Markus,
    Thank you for your feedback!
    -Alex-
