Wired Intelligent Edge
JL563A & HPE/Aruba 2920 Switch Compatibility
  • 1.  JL563A & HPE/Aruba 2920 Switch Compatibility
    Posted Oct 30, 2019 04:19 PM
    I've got an urgent need to utilize a copper-based 10GbE connection.  I've currently got a pair of 2920 switches installed with 2-port SFP+ expansion modules.  I've found on several websites where the JL563A SFP+ works with these 2920 switches.  I believe that the ArubaOS-Switch and ArubaOS-CX Transceiver guide also states that the part is compatible with the switch.  However, I could be misreading that guide.
    Can anyone confirm whether this JL563A RJ45 SFP+ works with the 2920 switch or not?
    Thank you for your help!
  • 2.  RE: JL563A & HPE/Aruba 2920 Switch Compatibility
    Posted Oct 30, 2019 05:03 PM
    Hello!
    The 2920 plattform ist arubaOS based not arubaOS-CX.
    In the arubaOS portfolio, only 1 GBE Cat5e transceivers will be supported (J8177D on 2540 and above, as far as I know).
    The J563A will be available for 8320 series and above.
  • 3.  RE: JL563A & HPE/Aruba 2920 Switch Compatibility
    MVP GURU
    Posted Oct 30, 2019 07:40 PM
    Sruba 2920 Switch series doesn't support and hasn't ever supported JL563A SFP+ RJ45 Transceiver (as reference read what was discussed here: https://community.arubanetworks.com/t5/Wired-Intelligent-Edge-Campus/JL563A-Transceiver-Support-in-8320/td-p/489224).
    That said if you need RJ45 10Gbps connectivity (through Cat.6A cabling) on Aruba 2920 you should use J9732A two RJ45 10GBASE-T ports Module...or, if maximum distance and peer compatibility shortcomings aren't a stopper for you, use supported SFP+ to SFP+ DACs cables (1, 3 or 7 meters long).
    In any case check Aruba 2920 Switch series QuickSpecs to understand what options are supported.
  • 4.  RE: JL563A & HPE/Aruba 2920 Switch Compatibility
    Posted Nov 06, 2019 07:36 PM
    Thanks to both of you for your answers.  Unfortunately, my requirement was that I use an Aruba 2920 switch.  I already had one module with both SFP+'s in use with 10 GB fiber transceivers.  I also had the second module installed with one SFP+ port in use by a fiber transceiver, leaving only the option to use a 10GB SFP transceiver -- which Aruba/HPE has seemingly decided to create as an supported option for this switch.
    Aruba/HPE have numerous gaps in coverage for both SFP/SFP+ transceivers and switch models that end up having to be filled by use of Cisco, Juniper and other network vendors.
    In the end, I found that an unsupported by HPE/Aruba option would be to use a third party 10GbE RJ45 transceiver.  This solution has worked perfectly and is a tiny fraction of the cost of the HPE/Aruba branded transceivers - of which I would have bought and used happily enough had the option existed.
  • 5.  RE: JL563A & HPE/Aruba 2920 Switch Compatibility
    Posted Nov 07, 2019 01:41 AM
    Hello!
    Yes, to use 3rd party transceivers is an option.
    You have to keep in mind, that there is no guarantee that they will work.
    ARUBAOS-SWITCH UNSUPPORTED TRANSCEIVER GUIDE V2.pdf
    But they do in most cases.
    I also use 3rd party transceiver for customers with "special" needs.
    For example, there were no original BiDi transceivers available or transceivers which offers 1 GB speed on multi modes fibers with 2 km (1.24 miles) and more - in such cases are 3rd party transceivers usefully.
    (There are also 3rd party transceivers existing which are coded with aruba partnumbers, they dont need the unsupported transceiver activation - but also not supported)
