L3 Roaming between Virtual controllers
  • 1.  L3 Roaming between Virtual controllers
    Posted Mar 31, 2019 11:22 PM
    Dear team,
    I am working with an implementation with 30 Instant APs 305 Aruba and need to implement Roaming between Virtual controllers.
    There are 2 buildings with different subnets and VLANS, and I was not able to find a clear documentation to configure L3 roaming between clusters.
    I have seen some forums mentioning that VLANs shouldnt match at both VC, and another that VLANS should match .
    I have attached both VC controllers, and "L3roaming events" for you to check.
    L3 tunnel are being established properlly, and IP is mantained for a while when one user from VC 650 moves to VC638, but for some reason the session is being disconnected.
    I have upgraded all VC and APs to 8.3 latest available version.
    This is Controller VC650: L3 configuration:
    l3-mobility
    home-agent-load-balancing
    virtual-controller 192.168.7.196
    virtual-controller 192.168.7.78
    subnet 192.168.192.64 255.255.255.192 505 192.168.7.78
    subnet 192.168.191.0 255.255.255.0 501 192.168.7.196
    This is controller VC538: L3 Configuration:
    l3-mobility
    subnet 172.18.0.0 255.255.255.240 192 192.168.7.78
    subnet 192.168.189.0 255.255.255.0 190 192.168.7.78
    subnet 192.168.160.0 255.255.255.128 160 192.168.7.78
    Thank you !!
    Attachment(s)
    docx
    roaming 638.docx   23 KB 1 version
