locked out after FIPS upgrade
  • 1.  locked out after FIPS upgrade
    Posted May 16, 2012 01:26 PM
    i just upgraded a 650 controller from 6.1.2.3 to 6.1.2.3-FIPS.  the upgrade went smoothly and everything posted properly with no errors on the reboot.  the problem i have now is it will not accept my login credentials.  is there a default password for FIPS that overwrote my config?  i have tried the "fipsadmin" default password from previous releases with no luck. i cannot find any documented default passoword for this release.
  • 2.  RE: locked out after FIPS upgrade
    Posted May 16, 2012 04:00 PM
    i have attempted the password recovery procedure with no luck also.
    (Aruba650-US) (config) #mgmt-user admin root
    Password:****************
    Re-Type password:****************
    Error : Non-Compliant to Mgmt Password Policy
    Internal error occurred, Password validation failed
    a little more background.....
    this system was originally running 6.0.1.0 and configured with a 9 character password (7 lower, 1 upper, 1 number).  the system configuration was all default with the exception of setting up trunks, vlans, and ip address.  the system was then upgraded to 6.1.2.3 on both partitions and then immediately upgraded to 6.1.2.3-FIPS on partition 1 after which i was locked out.
    i have no idea what the mgmt password policy would be as i never modified it.  any help getting back into this thing is appreciated.
  • 3.  RE: locked out after FIPS upgrade
    Posted Jul 13, 2012 07:50 AM
    Did you resolve this problem ?
    I'm locked the same way after initial web-wizard.
  • 4.  RE: locked out after FIPS upgrade
    Posted Jul 13, 2012 02:55 PM
    there is a process similar to the password recovery process on Cisco devices.  I couldn't find it documented anywhere but Aruba support was able to get me in and i captured the console session for reference.  You will lose any existing configuration and have to reprogram the device from scratch.
    1) perform a boot break from the console port at 'Hit any key to stop autoboot:'
    2) change the config file environment variable
    setenv cfgfile default1.cfg
    saveenv
    3) issue the 'reset' command
    4) reconfigure the device with the initial setup dialog, system will reboot when complete
    5) perform a boot break at 'Hit any key to stop autoboot:'
    6) unset the config file environment variable
    setenv cfgfile
    saveenv
    7) issue the 'boot' command
    8) login to device from console when prompted
    9) issue 'write mem' command
    i've attached the session capture for reference
    Attachment(s)
    txt
    boot break process.txt   8 KB 1 version
  • 5.  RE: locked out after FIPS upgrade
    Posted Jul 19, 2012 04:11 AM
    Thank you !!!
    It helps.
