So we picked up the AirWave solution and 10 IAPs for 4 of our locations. We've gone through and deployed/configured them how we want them in one location. Now we've added the new IAPs in a second location, gotten them ionto AirWave but are having problems copying the template from the first site to the second.
What we want is to have the same 4 SSID's in each location, one doing 802.1x authentication, one using captive portal and two guest-ish networks, each of them on different VLANs, etc. I would assume we need to change the VLAN ids and stuff manually, but so far we can't even get the basics of the template to apply to the new IAPs. Is there a general walkthrough on how to do this? The support guys I've been talking to are acting like this is a novel deployment situation, but it was sold to us as "What AirWave does"
Anyway, how do I take one locations template and apply to another location? We've copied the text of the template over, but it gets so far down the config and then just says it's stopping the processing of rules?
Continually shows Mismatched:
wlan access-rule iRoamX
Actual rule any any match any any any deny
Desired rule any any match any any any permit
