Comware
Maximum VRF Instance Support in Comware DC switches
  • 1.  Maximum VRF Instance Support in Comware DC switches
    Posted 17 days ago
    Hi Pals,
    We have requirement to propose HPE Comware DC switches with 512 VRF instance.
    Can we get HPE FF 5940 48XGT 6QSFP28 Switch (JH391A) to cater this VRF requirement, or if not, do we have another option from HPE Comware series?
  • 2.  RE: Maximum VRF Instance Support in Comware DC switches
    Posted 12 days ago
    512 VRF instances (vpn-instance) is quite huge ! Are you sure it's not "routing interfaces" ?
    Well, there is no clear limit expressed in the documentation concerning vpn-instances.
    5940 switches accept up to 2K vlan interfaces, but I guess vpn-instances limits are way lower.
    There is a hint on thread https://community.arubanetworks.com/discussion/5940-vrrp-limits : unable to create more than 256 virtual routers...
    Frederic MEUNIER
  • 3.  RE: Maximum VRF Instance Support in Comware DC switches
    Posted 11 days ago
    VRRP limit on 5940 is 255 instances.
    The limit for 5945, 5980 and above is 256,
    Best, Gorazd
    Gorazd Kikelj
    MVP Expert 2023
  • 4.  RE: Maximum VRF Instance Support in Comware DC switches
    Posted 2 days ago
    VRF is called Multi-VPN Instance Customer Edge (MCE) on Comware. The 5945 series support up to 4095 VRF/MCEs.
