VRRP limit on 5940 is 255 instances.
The limit for 5945, 5980 and above is 256,
Best, Gorazd
Gorazd Kikelj
MVP Expert 2023
Original Message:
Sent: Nov 25, 2023 01:41 AM
Subject: Maximum VRF Instance Support in Comware DC switches
512 VRF instances (vpn-instance) is quite huge ! Are you sure it's not "routing interfaces" ?
Well, there is no clear limit expressed in the documentation concerning vpn-instances.
5940 switches accept up to 2K vlan interfaces, but I guess vpn-instances limits are way lower.
There is a hint on thread https://community.arubanetworks.com/discussion/5940-vrrp-limits : unable to create more than 256 virtual routers...
Frederic MEUNIER
Original Message:
Sent: Nov 20, 2023 11:02 AM
Hi Pals,
We have requirement to propose HPE Comware DC switches with 512 VRF instance.
Can we get HPE FF 5940 48XGT 6QSFP28 Switch (JH391A) to cater this VRF requirement, or if not, do we have another option from HPE Comware series?
