Cloud Managed Networks
Forum to discuss all things Aruba Central and UXI Network Management, this includes Aruba Central managed networks, Central configuration, best practices, Central APIs, Cloud Guest, AIOps, Presence Analytics and Other Central Applications
Migrating AP-305's to Central
This thread has been viewed 23 times
  • 1.  Migrating AP-305's to Central
    Posted Dec 14, 2022 07:38 AM
    Hi all,
    Is it possible to migrate AP 305's from a local controller to Aruba central?
    If yes, what are the steps? Add them in devices and reset AP?
    Is there a tutorial or something anywhere?
  • 2.  RE: Migrating AP-305's to Central
    Posted Dec 14, 2022 04:57 PM
    for controller based APs to be managed by Aruba Central, they need to be converted to AOS10 APs.
    AP-305 is not one of the APs that is supported.
    Here is the Supported Devices for AOS 10.x
    https://www.arubanetworks.com/techdocs/AOS10_3_OLH/Content/aos10x/overview/supported-devices.htm
  • 3.  RE: Migrating AP-305's to Central
    Posted Dec 14, 2022 05:06 PM
    Can't they be converted to AOS8?
  • 4.  RE: Migrating AP-305's to Central
    Posted Dec 14, 2022 05:21 PM
    you could use AP Convert command
    see if this helps
    https://community.arubanetworks.com/community-home/digestviewer/viewthread?MID=32849
