Netflix + iOS streaming to Chromecast on Aruba Instant Network (IAP-225) - Not Working
  • 1.  Netflix + iOS streaming to Chromecast on Aruba Instant Network (IAP-225) - Not Working
    Posted Dec 15, 2017 08:08 PM
    Looking for some support here after finding no success in my searches. I have a flat network and am unable to stream content from Netflix on iOS to a Chromecast.
    All AirGroup services are enabled, Broadcast Filtering is disabled on the SSID, and I've followed this support document:
    http://community.arubanetworks.com/t5/Security/why-will-chromecast-work-with-everything-but-from-an-IOS-device/td-p/249359/page/2
    However, when using that support document I was unable to add (due to syntax) the following lines:
    _sub._googlecast._tcp
    _ca5e8412._sub._googlecast._tcp
    It would be great to get some support on this. Thanks!Screen Shot 2017-12-15 at 5.05.40 PM.pngScreen Shot 2017-12-15 at 5.05.17 PM.png
  • 2.  RE: Netflix + iOS streaming to Chromecast on Aruba Instant Network (IAP-225) - Not Working
    Posted Dec 16, 2017 01:33 AM
    Try disabling bonjour and dlna.
  • 3.  RE: Netflix + iOS streaming to Chromecast on Aruba Instant Network (IAP-225) - Not Working
    Posted Dec 31, 2017 06:30 PM
    That seemed to do the trick! Thanks.
    See the attached screenshot for anyone looking for more info.
  • 4.  RE: Netflix + iOS streaming to Chromecast on Aruba Instant Network (IAP-225) - Not Working
    Posted Jan 13, 2018 04:23 PM
    It appears that I'm running into the same issue.  I'll try to explain things in detail so that there is no confusion.
    Basic Info:
    My WLAN Settings:
    Services:
    Everything appears to be identical to those from sevenseventyeight.  I have read some additonal articles that referred to running a 'show airgroup blocked-services id' command, but when I run it, I get a parse error.
    I also read in a Google help article that talks about disabling Client Isolation (https://support.google.com/chromecast/answer/3213084?hl=en) , but I'm not sure where I do that.
    Since this is a very basic home configuration, I have supplied the overall config file.
    I hope I have provided enough information.  I look forward to a response.
    Chris
    Attachment(s)
    txt
    ArubaInstantConfig.txt   3 KB 1 version
  • 5.  RE: Netflix + iOS streaming to Chromecast on Aruba Instant Network (IAP-225) - Not Working
  • 6.  RE: Netflix + iOS streaming to Chromecast on Aruba Instant Network (IAP-225) - Not Working
    Posted Feb 08, 2019 12:18 AM
    Very helpful info, just did what it is mentioned and chromecast was discovered on serveral apps that chromecast can cast, thanks for the help!
